Old 08-30-2015, 02:46 PM   #1
Beginner
Jamesp's Avatar
Adding door speakers and wiring Part1
I posted an unanswered request for help on this so this may be the first DIY for it.
Bring plenty of patience patience.
Take the door panel off - this is easy
Cut out a hole on the door panel with the speaker cut out template. Be sure the speaker will have clearance with the metal structure behind the door panel.
Check the fit
It fits, screw it to the panel with the grill clip interface
Install the grill
Run the wires from the door to the cabin using the existing wire harness splash shield running between the door and the car
Remove the screw at the bottom of the connector splash cover, open the connector by pulling out the connector bail at one end of the connector
note bail open at bottom of connector (passenger side)
Look for open holes in the connector to run speaker wires through
Disconnect the wire harness clips in the door, pull the splash guard sealing end through the hole square hole in the door to access and peel back the rubber shield around the wire harness in the door. Use screwdrivers to open a passage between the rubber water shield and plastic shrink tube over the factory harness. Push speaker wires into the gap and through the splash guard tube.
Smash the end of the other speaker wire flat with pliers to make it easier to pull later
2003 S manual
Old 08-30-2015, 02:48 PM   #2
Beginner
Jamesp's Avatar
Adding door speakers, part 2
Tape the second speaker wire to the first to pull it through the splash guard. Start wrapping tape away from the end of the second wire, and wrap to it to and over the end of the second wire so the edges of the tape wrap lay correctly
Run the wire though the door side connector
Then through the car side
Use a bent coat hanger to push both wires into the cabin through the weather seal the car side connector harness goes through.
The wires come into the cabin just behind the lower right front corner of the glovebox onthe passenger side. Still have to do the driver side
2003 S manual
Old 08-31-2015, 06:51 AM   #3
BruceH's Avatar
Nice write up, luckily I already had speakers so it was a simple swap for me
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 05-11-2017, 02:37 PM   #4
speaker size?
Any idea on maximum size of the speaker you can comfortably place? I'm guessing you went with something over 6"What speaker did you go with specifically? Thanks in advance and love the post.
cnosek87 is offline   Reply With Quote
Old 05-15-2017, 04:30 PM   #5
Beginner
Jamesp's Avatar
I put in 6 inch Infiniti Kappa. Not room for much more than that. I'd recommend going with subs in the doors. the full range speakers did not add as much as I'd hoped over the dash speakers, which are infinity reference.
2003 S manual
