Old 08-03-2015, 01:14 PM   #1
Accusump installed
Thought I would post some pics of my accusump installation, it sits inside my cabin behind my engine bay between the rear shocks, I have a rear strut brace and still managed to fit it all in. I will post a how to when I tackle the electrics as I will be using a oem switch fitted into a blank spot in my centre console. I have run the wiring in the mean time.
I used a sandwich adapter along with a billet LN re-usable oil filter. The sandwich/re-usable filter set up measures 20mm longer than the standard oem filter housing. I have a LN 0.5 quart deep sump and for all practice purposes you can say the new filter set up's bottom is flush with the pan's bottom.
I bought all the parts for my installation in a kit from LN, the build quality was awesome on everything. The actual filter housing and its cap was un-anodized so I had it anodized red locally. Nobody will ever know except me, but I'm still glad I did it just because I can
de-snorkeled, clear lights, sports exhaust, zeintec hard top, zein wing, B&M short shifter, DesignTek lowering springs, DesignTek carbon fibre strut brace front and rear, 18'' carerra 5 spokes, semi slick tyres, entire soft top delete, engine cover delete,red console,L&N deep sump, volo performance chip, raptor shift light, de-cat'ed, OEM GT3 bucket seats.
sickbananas is offline   Reply With Quote
Old 08-03-2015, 01:22 PM   #2
Old 08-24-2015, 11:48 AM   #3
jaykay's Avatar
Nicely done!! I can't belive you got it in there! What size is the unit? What mounting hardware / method did you use?
I suppose removal of the foam insulation helps....as I recall that may affect the route to the drains
986 00S
