Old 04-09-2017, 04:39 PM   #11
Do you have a DVM with continuity check? If not, a simple test light will work.
The best way would be to disconnect the door harness at the door jamb and test every switch from there. The pins on the door jamb connector should be numbered, but I can't check until tomorrow.
Let me know what you have for testing and I'll write up some instruction for testing everything (test will be the same for both doors and I suggest doing both). The test shouldn't take more than 10 minutes, but you'll really need a second person to pull the levers and turn the key while you probe the contacts.
