-   -   new radio resets when power is off (http://986forum.com/forums/diy-project-guides/56125-new-radio-resets-when-power-off.html)
jeepdad 03-05-2015 05:43 AM
Hi everyone.
I have a small hiccup on my quest for better sound. I installed dash speakers a couple of weeks ago, and last night swapped out the factory head unit for a new Pioneer with bluetooth, USB, etc.. It sounds pretty good but I miss the factory look of the Becker.
The problem is the radio resets/loses memory when the ignition is turned off. I wired the factory harness as directed so I'm not sure what is going on. I watched a Youtube video where a guy suggested swapping the red and yellow wires connections between the harness and radio din. I'm somewhat afraid to do this.
Any ideas?
antny 03-05-2015 05:49 AM
You need to reverse the red and yellow wire. The red is the switched power and the yellow is constant. I.made the same mistake.
jeepdad 03-05-2015 06:02 AM
Thanks! I'll give it a go tonight.
dghii 03-07-2015 07:52 PM
+1 for the solution. I had the same issue when I installed my JVC head unit last year.
jpc763 03-15-2015 03:05 PM
I'm installing a double din Pioneer with a Eurosport kit. Will I need to do this as well?
antny 03-22-2015 08:59 PM
Yes you will
