Old 02-05-2015, 05:09 PM   #1
amagalla's Avatar
Doing IMS. What else should I do while I'm in there?
I'm going to be doing the IMS in a few weeks. While I'm in there, I'm also doing:
RMS
Luc Clutch kit
dual mass Flywheel
Manzo Exhaust/TopSpeed test pipes
AOS
serpentine belt
spark plugs
Is there anything else I should do while I'm in there?
Tony
Lapis Blue 03 Boxster S
Old 02-05-2015, 06:06 PM   #2
Reebuck1
needs
You may need a new MAF and new oxygen sensors.
Reebuck1 is offline   Reply With Quote
Old 02-05-2015, 07:03 PM   #3
While you are doing spark plugs, you may want to replace the spark plug tubes if you have any oil leaking from them. Also, get some clutch spline grease for the transmission input shaft and inspect your CV joint boots. If you have torn boots, you may want to order new boots and associated parts while the tranny is out.
Viper10000 is offline   Reply With Quote
Old 02-05-2015, 10:38 PM   #4
amagalla's Avatar
It's an 03 so we don't have oil tubes. I like your thinking though.
Old 02-06-2015, 03:54 AM   #5
Beginner
Jamesp's Avatar
Make sure you replace the bearings associated with the clutch and the clutch fork pivot point tends to fail (non metallic sphere beaks off) so you might replace it as well. You'll also be in a position to easily change your transmission oil. I missed that one and now I'll be doing it under the car. Ugh!
2003 S manual
Old 02-06-2015, 11:42 AM   #6
It would be worth inspecting the oil fill tube and replacing if necessary.
spendy is offline   Reply With Quote
Old 02-06-2015, 09:37 PM   #7
amagalla's Avatar
Recommendations on transmission oil?
Old 02-06-2015, 10:44 PM   #8
Beginner
Jamesp's Avatar
Here's a link http://986forum.com/forums/general-discussions/55685-my-box-resists-shifting-cold-mornings.html
2003 S manual
Old 02-07-2015, 12:41 PM   #9
RayW's Avatar
Good time to check / change axle boots. Do you need the IMS bearing tool?
RayW is offline   Reply With Quote
Old 02-07-2015, 02:34 PM   #10
Water pump. While not at the same end of the engine, since you are doing the belt....
Also check all idler pulleys.
Old 02-07-2015, 07:39 PM   #11
amagalla's Avatar
Thanks but, no. I bought the tool already.
