Old 09-16-2019, 10:44 AM   #681
Ben-Auto-Design
Ben006's Avatar
Try that "wetransfer" link : https://wetransfer.com/downloads/d137d3a60625e5434cb7c77e8ac89e3520190916174325/bdfd83
It should work, it's a PDF with instructions
Porsche Tech in France.
www.benautodesign.fr
1982 928 S Euro
Ben006 is offline   Reply With Quote
Old 09-16-2019, 12:48 PM   #682
Originally Posted by Ben006 View Post
it's a 10mm hole, I can't tell you what that equals too in inches :/
I'll try something to post the instructions here
The existing hole is 10mm but the bolt you provide is larger than that so the existing hole has to be enlarged . I provided the info to what I had to do I suggest anyone else to measure the OD of the bolt and drill accordingly .
Old 09-17-2019, 04:53 AM   #683
Send a message via Skype™ to Terryg
Originally Posted by rfuerst911sc View Post
Online conversion charts state 12MM is equal to 15/32 .
Mine said that 15/32 was slightly smaller and since the whole point of the lever is to minimise slack I thought I had better ask, I am nervous that a 12mm drill bit on plastic may come out slightly more, I'll keep the speed down or maybe drill smaller and ream it out.
Thanks,
Terry
Terryg is offline   Reply With Quote
Old 09-18-2019, 04:01 AM   #684
Thanks,
Terry
If you can take any scrap plastic you might have and drill the 12mm hole and check for fitment . If too large then your idea of drilling smaller and reaming out is a good one . In my case 15/32 was tight I had to work the bolt to get it in which is what I wanted to eliminate any excess play .
Old 09-18-2019, 10:15 AM   #685
Ben-Auto-Design
Ben006's Avatar
Hi guys, have you been able to download the instructions from Wetransfer ?
Yes, the hole is already 10mm with two flat spots. You have to remove the flat spots, then drill further at 10mm to make room for the long bolt.
It's how I intended to work, but it might be just fine if you drill it at 12mm and let the bolt go through !
The problem I see with that is that the nut won't be tight, and if you try to tighten it too much it will bend or break the plastic base.
Drilled at 10mm
Bolt goes through but stops on the first plastic wall :
Nut is tight against the wall that is against the bolt' shoulder, there is no play.
I hope it's clearer now
1982 928 S Euro
Old 10-04-2019, 01:51 PM   #686
01 Basalt Metallic 986
JimmyBad's Avatar
What’s the feedback on this?
JimmyBad is offline   Reply With Quote
Old 10-04-2019, 03:09 PM   #687
2003 Base 5-speed
grc0456's Avatar
My install of the side lever has tightened up the side to side play in the shifter when in gear. I’m using in conjunction with Ben’s ball bearing SS, and I am very satisfied.
Old 10-04-2019, 09:05 PM   #688
The file is no longer available. Maybe you can put it on mega.nz or something else.
Old 10-04-2019, 09:45 PM   #689
I haven't got near this yet, I may wait now until I go home as I have a large garage I keep it in for the winter. In the summer it is parked outside where I live while working in UK.
Old 10-05-2019, 01:03 PM   #690
Available exclusivley in the USA through uniWerks Design. :-)
https://uniwerksdesign.com/product/bens-porsche-996-986-short-shifter/
uniWerks Design is offline   Reply With Quote
Old 10-05-2019, 01:04 PM   #691
Just received an email from Chris with the install instructions , very quick service I have purchased another shifter housing so I plan on doing the bench work this weekend . I am going to take this opportunity to strip my console down and paint it silver to match the car .
Anytime! :-) CHeers!
Chris
Old 10-06-2019, 07:22 PM   #692
98 Arctic silver 986
tommy583's Avatar
I ordered the new part this evening. Since it's just coming down the Thru-way a couple hundred miles, I hope to have it in a few days. If so I'll have it in by the weekend and report back how well it works to clean up the side to side movement of Ben's shifter. I'm expecting a new center console to arrive this week as well. I might as well put them both in at the same time.
Old 10-07-2019, 10:21 AM   #693
Ben-Auto-Design
Ben006's Avatar
Thanks guys for the feedbacks
I'm sure you'll like it Tommy !
Thanks SmallBlock454 for the reminder, I'll fix that !
Ben
1982 928 S Euro
Old 10-10-2019, 05:29 PM   #694
tommy583's Avatar
Well put the part in today. Took me about an hour to remove the shifter and put the part in. I already had Ben's short shifter. I took the whole kit out of the cradle. Shifter, bearing cups and old parts. Pro tip, when putting everything back together put the new part and shifter in together. DO NOT bolt the new piece in until the shift lever and new piece are mated together. You can not get the shift lever into the cradle if you bolt the new piece in first.
Anyways it went pretty smooth. Chris sent me a PDF email of the directions. The new part really cleaned the side to side slop of the factory part. There is still a little play but, it is easy to see it's coming thru the cables. Probably caused by some slop on the transmission connections. I'll have to take a look at that at some point. I'm happy overall, I just hope it stays this way for a while before I have to change the insert. It looks like it will be a complete teardown to change the insert.
Old 01-13-2020, 11:50 AM   #695
Ben-Auto-Design
Ben006's Avatar
Thank you for your feedback !
It is a bit more involved than just the shifter, yes !
How long did it take you ?
I'm working on a new prototype shifter, it will not use the Porsche shift knob but will fit any aftermarket shift knob !
Here is the first piece of the puzzle :
Ben
1982 928 S Euro
Old 01-21-2020, 10:04 PM   #696
Shapeshifting Lizard-Man
WizardSmokey's Avatar
Hey Ben,
If you need anyone to thoroughly test your new shifter in a racecar setting, let me know! :P
WizardSmokey is offline   Reply With Quote
Old 01-22-2020, 05:47 AM   #697
Who's askin'?
maytag's Avatar
Are there no instructions included with the part? Mine arrived yesterday, but I haven't opened the package yet. I currently have the shifter exposed because I just replaced cables. Do I need to remove the "cradle" from the car to install this side peice?
Old 01-23-2020, 01:10 PM   #698
Who's askin'?
maytag's Avatar
Does anyone have these instructions they could post, or send to me?
Old 01-23-2020, 02:23 PM   #699
Here's a link to the install instructions for the side lever.
9X6-9X7-SHIFTER-SIDE-LEVER-1
loflyingz is offline   Reply With Quote
Old 01-23-2020, 05:55 PM   #700
tommy583's Avatar
I have the PDF. PM me your email and I'll send it to you.
