Old 08-04-2014, 08:39 PM   #1
Pdwight's Avatar
Caliper Decals And faded paint
My S Calipers are dull and faded, all the clear coat is gone. I was thinking about spraying them red with Caliper paint (after surface prep of course). I Was curious if you used the eBay decals or what ?
Also do you apply the decals and then a few coats of clear coat ?? I cant see a caliper decal lasting long in that environment.
I have some wheel clear coat...or is there a high temp type for calipers ??
Thanks in advance
Dwight
Old 08-05-2014, 07:38 AM   #2
BruceH's Avatar
Dwight, I did this about a year and a half ago and they still look perfect. I followed this thread:
Painted Calipers
I used VHT Caliper paint and clear coat.
http://www.amazon.com/gp/product/B000CPJLVC/ref=wms_ohs_product?ie=UTF8&psc=1
http://www.amazon.com/gp/product/B000CPJLV2/ref=wms_ohs_product?ie=UTF8&psc=1
I did not remove my calipers, just the pads. I bought the decals from eBay and used 3 coats of clear coat. Very easy to do and makes a huge difference!
Here is another thread with tips:
http://986forum.com/forums/general-discussions/35410-red-caliper-paint-%96-closest-original.html
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 08-05-2014, 08:41 AM   #3
Pdwight's Avatar
Brake Line Cap
Is there such a thing as a brake line cap or something to stop the fluid from gravity draining ?
Old 08-05-2014, 08:51 AM   #4
JayG's Avatar
in honor of our departed friend, you could use a potato LOL
Old 08-09-2014, 03:26 PM   #5
woodsman's Avatar
Exclamation
It's common to lightly clamp on a small vise grip around the flex hose. You can wrap the hose with a piece of cloth first in order to protect it. It may be wiser yet to replace the (10-14 yr. old) flex line with OEM or Stainless lines after the painting is finished as they're probably original to the car.
Old 08-09-2014, 05:04 PM   #6
Pdwight's Avatar
Cap Block
It looks like someone would make a cap block with female threads so you could just cover the end. On older non ABS systems it was irevelant as bleeding was such a cinch....I worry about the ABS pump getting air in it in the event of a total drain of the system.
