Old 05-18-2014, 04:02 AM   #1
WALDMEISTER
BRAN's Avatar
How to attach the Boxster badge?
It is probably one of the most difficult questions to answer (hope not ):
How to attach a hard plastic (no original adhesive anymore) Boxster badge on the soft "plastic" dash underground?
I am sure there most be a special adhesive/glue for that, or maybe not?
That is the task (see below):
Thanks for any hints in advance.
Old 05-19-2014, 11:04 PM   #2
SKOOSH1970's Avatar
I would suggest a good contact adhesive, slow curing and apply with a small paint brush, or, a good spray carpet adhesive.......??
SKOOSH1970 is offline   Reply With Quote
Old 05-21-2014, 03:07 PM   #3
Make sure the adhesive does not lose it's properties in high heat. A car sitting out in the sun can really test an adhesive. You don't want to find the Boxster emblem resting on the spoiler after a day in the sun.
Old 05-22-2014, 07:36 AM   #4
WALDMEISTER
BRAN's Avatar
Thank you guys, so far!
I am going to try the
3M™ VHB™ Tape 4941
Flexibility of Materials:
One Substrate Flexible, Both Substrates Flexible, Both Substrates Rigid
Tape Thickness 0.040 in (1.0mm) - 0.045 in (1.1mm)
Temperature Resistance - Initial 300 Degree Fahrenheit
Temperature Resistance - Long Term 200 Degree Fahrenheit
If that is not going to work, nothing will
Maybe I have to concider pinning the emblem on there, somehow
Old 05-30-2014, 08:38 AM   #5
WALDMEISTER
BRAN's Avatar
Got the 3M VHB tape: Testphase started
...did not come off so far (24h)
...not even after a hot, sunny afternoon & full sun on it
