05-10-2014, 09:15 AM
Stereo Modding :-)
So I thought I would start my modding off with the basics. Air filter, pollen filter and car stereo.
Took me a while to get the original stereo out. I'm great at breaking things and having extra bits left over so thought I would take my time. I still managed to cut my hands but that's part of the fun right?
A good tip and will save time (wish I had done this first). Putting the pins in to remove the stereo use screw drivers to pull on the thin metal pins not your fingers. Took a while to hook both sides in but managed to pop the stereo out.
On the back there are 3 connectors for the original stereo. I have the cd changer in the front so think one is for that. Blue, green, yellow connector. Can someone confirm?
I have a harness for two of the 3 connectors but might go and buy a 3 way before I install and have to remove it again. Another tip you will need an antenna adapter for the arial at the back if using some types of after market stereos so check to see if one is needed. I had to run down to the car shop 5 mins before they closed to get one.
In the cubby hole where the stereo came out of there are some outlets where hands free mic can pass through nicely. Was pretty easy to route it through. I will finish off the install tomorrow but thought I would post a few pics before and after or half way through
05-10-2014, 12:38 PM
One other question I should ask. Maybe I should have asked this first before buying a new head unit. I have the Bose system. Will I still be able to use the factory amp/speakers?
I read on another forum that the head unit changed but the guy had no sound and was suggested it could be that the amp switched on with the factory head unit.
I would rather do the install myself than take it to a shop.
05-10-2014, 02:49 PM
What's your model year?
05-11-2014, 12:52 AM
Model 3.2s year 2002
05-11-2014, 02:59 AM
So. There are no wiring harnesses that i can find that do the 3 connections blue, green,yellow. Cd changers are now obsolete so no need for me to worry about that connection. However connecting just the two connectors below gave me no sound so either blue,green or yellow will be the amp
Any ideas how to get around this before i put the stock radio back in?
05-11-2014, 04:36 AM
And I forgot to add I have the Bose system. Shelf sub, door speakers, cd changer and amp in the front trunk
05-10-2014, 08:46 PM
I am not sure with the Porsche/bose setup it you can reuse the components, but with my Miata, I have removed the bose head unit and installed an aftermarket stereo and all is great, just purchased a wiring harness adapter soldered it into the stereo's harness and it plugged right in without a problem. all of the controls are fine (f/r fader, r/l balance, power antenna etc.)
1977 Toyota Celica GT
05-11-2014, 04:51 AM
I could be wrong, but I think you have a car built on the MOST system, which is comprised of fiber-optic cables connecting everything important in the car. If this is the case, you probably have to do additional work and replace a few extra things to go aftermarket and use your factory speakers.
Do some research on the MOST system and your model year and verify this is correct.
05-11-2014, 05:06 AM
I will have a look. Though MOST was from 2003 onwards but will look. I thought this would be a simple plug and play job
05-19-2014, 12:39 PM
I don't have the bose system in mine, but when I was buying the adapter for my after-market unit I had to specify bose or non-bose system. I would assume that means there is an adapter for bose units.
when I ordered my kit and from euro motorsports, they asked me the model, make, year as well as the original stereo model number and the model unit I was putting in. I think they custom make the cage and face plate.
05-19-2014, 11:24 PM
What Radio
unit do you have installed? I see it interfaces with the smartphones. I'm looking for the one just like that. Did you have the Hifi (with the EQ on the bottom)?
2000 Boxster S (986)
De-snorkeled withK&N Cold Air intake
Short Shifter 14mm spacers F&B
Secondary Cat delete
Top Speed Test pipes and Exhaust
05-20-2014, 07:10 AM
I had the CDR-220 with the CD holder underneath. this unit is the Parrot Asteroid Smart
I lost my cup holders to fit it in, but it was worth it. the BT handsfree and voice commands are excellent. it connects well to just about any smart phone. they have their own app store, but you can also install the android app store and others. it has it's own GPS or you can use Waze (free) or Tom Tom or several others.
it also has built in wifi and you can tether it to you phone (if you have hotspot) for internet on the go. you would need this for apps like waze. you can also plug in a usb 3g or 4g dongle for its own internet, but I wasn't going to spend that much.
the only things I don't like about it is that there is no physical volume buttons and it takes a while to boot up if it has been off >30 minutes.
05-20-2014, 11:38 AM
I think you are right. I did order the Bose harness but looking at the pins some are blank where pins should be. I have the pelican wiring guide but bought this as a plug and play so will go to the shop get them to do the wiring.
Thanks for the reply
05-26-2014, 06:05 AM
Fully fitted stereo - finally
Finally fitted my aftermarket Pioneer stereo in place of the factory fitted setup. I managed to find a harness on eBay:
(Autoleads PC9-410 Active Full Bose Amplifier Adaptor Porsche Boxster Cayman) by a seller called rudiemods here in the UK
This fitted and worked on my Bose setup. I have had to forfeit the CD changer unit in the front trunk but now I have the Bose amp and door/shelf sub working well. So well pleased with the end result. All for £80 too
Make sure you connect up the blue and white wire from the harness in to the remote wire this fires up the Amp and all should be fine.
