Old 04-21-2014, 12:52 AM   #1
Headlight removal issue, help please
Hi
I have a MY2003 986 with a problem with the headlight removal mechanism. I've had the car for about two years and never had to remove a cluster until today.
Upon trying to I found the hex attachment on the release bar is corroded and rounded off (picture attached), has anyone had a similar experience and could share the solution?
Thanks for any help
SmegHead
SmegHead is offline   Reply With Quote
Old 04-21-2014, 01:04 AM   #2
Nine8Six's Avatar
1. clean off the rust of the hex the best you can (toothbrush ? dunno)
2. use an old hex key/wrench and epoxy the tip inside the hex
3. wait a few days (24~48hrs) for the epoxy to cure
4. spray wd-40 inside that thing, unlock your headlight
5. heat up the hex key/wrench RED to release the epoxy
6. remove your headlight
just a wild guess... not that I had to do it before
Luck mate
Old 04-21-2014, 01:08 AM   #3
Nine8Six's Avatar
if you ever have to use the heat-up red option, watch for the carpet when your hex wrench goes off
Old 04-21-2014, 02:08 AM   #4
Thank you, like the idea. Do you think the epoxy will hold it ok?
Old 04-21-2014, 02:19 AM   #5
Nine8Six's Avatar
nope, that is a lot of rust. Cheap finding out anyway and I can't think of anything else for the moment
wait a tad... some others will try to help you out that's 100% certain
Welcome to the forum
Old 04-21-2014, 02:49 AM   #6
Nine8Six's Avatar
might be as simple as that:
you just never know with these cars... it might be just as fast to remove a fender than to go hunting local stores for long nose wisegrip and epoxy resins
Old 04-21-2014, 04:03 AM   #7
I only wanted to remove them to polish them up a little. Polished the rest of the car over the last couple of days and fallen in love with it again.
Doesn't look bad for approaching 190k miles does it
Old 04-21-2014, 04:15 AM   #8
Nine8Six's Avatar
(special color!pfff ) seriously it is absolutely stunning. Looking just as new to me actually
like the wheels, and a huge fan of your pebble style driveway
where in the EU exactly?
Old 04-21-2014, 04:18 AM   #9
Orient red apparently, my mates rib me it's pink.
Worcester UK
Old 04-21-2014, 04:22 AM   #10
Nine8Six's Avatar
UK
I know mate, just pulling your leg
Old 04-22-2014, 07:49 AM   #11
BruceH's Avatar
That is an incredible color, very nice! Some penetrating oil may help. Good luck with getting it to move
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 04-22-2014, 09:15 AM   #12
That post is pretty far in there and tough to snap loose even in excellent condition.
My verdict: it's never coming out that way again. Your best bet is to try to gain access to the tray retaining bolts via the wheel well and/or underneath and remove the headlight with the tray.
Once out, it will be simple to separate the two and replace the tray with a new one.
I would do this at some point. Going to need change one of the bulbs eventually.
Old 04-22-2014, 09:48 AM   #13
Thanks all, think I'll take a closer look and have a go at this weekend. I'll let you know how it goes.
Old 04-22-2014, 02:32 PM   #14
BruceH's Avatar
In the long run, you are probably better off going with Particlewave's advice. Remove the wheel, then fender liner and remove the tray/headlight assembly as one. If going the other route, spray some penetrating lube now, some more each day, and maybe by the weekend it will be ready.
DEPO Tail Lights
