-   -   Euromotorspeed Double DIN vs. Car Audio Innovations (http://986forum.com/forums/diy-project-guides/51098-euromotorspeed-double-din-vs-car-audio-innovations.html)
amagalla 03-09-2014 07:51 PM
I'm curious why more people are using EuroMotorSpeed kits as opposed to Car Audio Innovations. It seems that the car audio innovations kit comes with everything plus the top cubby. This part alone is typically $60 from what I've seen. Am I missing something here?
Thanks.
Tony
amagalla 03-12-2014 08:24 PM
Bump. Has anyone used the Car Audio Inovations kit? Seems like a fair price.
Ckrikos 03-13-2014 09:07 PM
I have used euro motor speed' skit and thought it was great. I actually just ordered another for my turbo.
kiyakubuke 03-17-2014 02:41 PM
this weekend I installed a Parrot Asteroid Smart in my '01 Boxster S using the euro motor speed double din kit. I was very pleased with it. can't speak to the Car Audio kit since I have never used it.
it worked great for me. the cage fit well after some minor adjustment to the dash trim with a dremel tool. very solid fit, the trim piece fit perfectly around the head unit, replacing the trim that came with the unit and fit perfectly in the dash. at first I was concerned because there didn't seem to be any mechanism for securing the trim piece. no tabs that snapped into the cage etc... but it fits so tightly in the dash that it dozen't move at all.
Tip to anyone that doesn't know. there is a wire that connects to dash trim. you have to unplug it to get the dash trim out. it is part of the alarm system. basically when the factory head unit is pulled out, it makes contact and creates a short. if you replace the factory unit with an aftermarket, it will be in the short position and your alarm will not arm. doors will lock, but the alarm will not arm, depending on your model you will hear the horn chirp a few seconds after trying to arm the alarm. while researching this, I came across some "kits" to fix this issue, but basically all you need to do is leave that wire unplugged and make sure it can not touch metal and ground out.
amagalla 03-18-2014 09:08 PM
Well, I pulled the trigger on the Car Audio Innovations kit. The main reason is that they are a Kenwood reseller, so the $199 kit included the Kenwood cage (as well as the upper cubby that I would have had to order). I have a JVC that uses the exact same cage, and Rod (owner) offered to make a custom bezel for the JVC. I can't wait till it gets here to see how the stereo, custom bezel, and the car will look together.
kiyakubuke 03-25-2014 05:06 PM
2 Attachment(s)
here is the end results:
http://986forum.com/forums/uploads01...1395792390.jpg
http://986forum.com/forums/uploads01...1395792410.jpg
