Old 02-27-2014, 11:51 AM   #1
Bumperettes removal from 2001 986
I want to paint the black bumperettes on my 986 but can't seem to remove them from the bumper. I have no problem getting the bolt out on each but can't seem to get the bumperette to fall off and I didn't want to force it. Once the bolt is out do I just tug the bumperette straight back or do I have to slide it or tilt it to remove?
Thanks for the help
Old 02-27-2014, 12:24 PM   #2
petrol head
would like to help but no bumperettes over here in the uk, sorry mate
always porsche is offline   Reply With Quote
Old 02-27-2014, 12:56 PM   #3
Never mind, got them off, they just needed a good tug (don't we all)
Old 02-28-2014, 10:41 AM   #4
I've done this job a few times using a bumper paint. I worked great and holds up quite well. I'm sure you'll be proud of the results.
Old 02-28-2014, 12:57 PM   #5
Ordered my primer, paint and clearcoat from Touch Up Paint and Accessories | AutomotiveTouchup
have used this vendor before and liked it. I highly recommend their products, both pens and spray cans for your painting needs.
In about 2 weeks I will be sporting some Slate Grey Metallic bumperettes.
Old 03-12-2014, 05:43 AM   #6
mikesz's Avatar
I have removed mine completely along with the brackets. Ordered a piece of ABS plastic, cut to size and attach to the area where the bumperettes were and license plate. I think I will leave it black. My car is arctic silve and I think the black would be a nice accent piece. But I might paint to match car.
99 Porsche Boxster
Old 03-12-2014, 06:23 AM   #7
Dlirium's Avatar
That sounds clean. Post a pict when you can!!
Old 03-26-2014, 05:24 PM   #8
mikesz's Avatar
Here is rear bumper with bumperettes removed and filler plate installed.
99 Porsche Boxster
Old 04-01-2014, 06:43 AM   #9
Bumperettes Painted
I finally got a chance to paint my bumperettes. Bought primers and paints from Automotive Touch up Paints. Project came out beautiful, even on a Metallic Slate color. Did the whole project for less than $50 delivered, with plenty of paint left over for future needs.
I used Adhesion promoter (3 coats), Primer (3 coats), then wet sanded with 1000 grit, Paint (5 coats), Clear Coat (5 coats). Put bumperettes in a cardboard box with a 40 watt lightbulb and let them cure for 4 hours, voila!
I'll post some pics once the sun comes out again. We haven't had rain all winter and now we actually are getting rain for the next few days, go figure.
Old 04-01-2014, 10:38 AM   #10
"filler plate"
That's a good idea.
Old 04-01-2014, 11:45 AM   #11
mikesz's Avatar
Talking
@Randall,
there is a company that sells a "filler plate', aluminum for $200. I bought a piece of ABS, made my template then had it cut by a glass shop. Much less than $200!
99 Porsche Boxster
Old 03-19-2018, 01:22 PM   #12
2000 Boxster S
Booker42's Avatar
I am going to be tackling this 'filler plate" project this weekend, painted to match car. Wish me luck, will post a pic when complete.
Booker42 is offline   Reply With Quote
Old 03-21-2018, 01:31 PM   #13
Christian H's Avatar
UK Boxster don't have bumperettes fitted but I wanted a contrast around my licence plate so fixed some black vinyl in the recess.
Christian H is offline   Reply With Quote
