Old 05-05-2013, 10:02 AM   #1
Yet another garage door opener install
I went for a clean self contained install of a garage door opener in the batwing. Picked up a rear defroster switch and was inspired by this guys install clicker to use a double pole reed switch to simultaneously light the switch led.
Parts :
Keychain opener - new Ebay
2 switch batwing - new
late style matte finish defroster switch - used Ebay
late style matte finish switch blank - new Ebay
OE porsche switch socket and connectors - new
DPST reed relay and DIP socket - Mouser
Schematic :
This shows why you can't simultaneously activate the remote and light the switch status LED. The switch common is +12V and the LEDs are switched separately to ground in normal use by the control relay in the car. The DPST reed switch allows you to do both.
Finished assembly and wiring :
The absolute hardest part of this project was snapping the switch blank into the batwing. It took me 30 minutes and sore fingers to finally get it seated.
Wires routed out of remote case :
Two wires come straight off of the microswitch in the remote, the other two come straight off of the +/- terminals of the battery. This remote uses a standard 12V which is perfect to activate the defroster switch status light and should last a long time. The reed relay is correspondingly a 12V version.
Socketed reed relay. Decided to do this rather than risk soldering straight to a $6 part. Plus it can be easily swapped if it dies in the future.
Parts secured in with velcro and sticky tape.
Finished install with bright status light and yes, the garage did open too.
teleski is offline   Reply With Quote
Old 05-05-2013, 04:41 PM   #2
jaykay's Avatar
Slick! So do you feel this is the best arrangement after all your research?
Will the signal be strong enough from down low in the car?
986 00S
Old 05-09-2013, 01:09 PM   #3
Signal range is fine for my needs. Haven't really tested from how far it will work.
This was the best arrangement for me. Easy integration into the car, cute challenge to wire up the status light and it looks great.
Old 05-09-2013, 03:06 PM   #4
Nice work! The little defrost symbol kind of looks like a garage door, too.
Old 05-16-2013, 11:14 AM   #5
Moderator
Very cool, nice!
Old 06-12-2013, 12:44 PM   #6
mikesz's Avatar
I installed one on my motorcycle, connected it to the Hi-Beam switch. I might do the same on my boxster. GOOD IDEA!
