Old 04-18-2013, 03:43 PM   #1
Cool DIY USB charging port
Another rainy day...so I decided to install a USB charging port in one of the empty spots near the e-brake. Sure, I could have purchased one of those tacky add on USB ports, or converted an existing charger, but I had all of the components on hand, so I scratch built the whole thing
This circuit is a regulated 5VDC, 1amp supply and will charge any USB device.
Old 04-18-2013, 03:58 PM   #2
Heiko's Avatar
Looks good... Sometimes the little self made items work the best...
I bought one of those 'tacky' ones but hid it in the back of the empty tray below the radio and used it for GPS power (I can also charge the cell off of it)
Nice job...
Heiko
Previously owned:
Old 04-18-2013, 04:33 PM   #3
San Diego Boxster
drbodzin's Avatar
Nice work! Love the creativity. Obviously you know a thing or two about electronics
Happy Boxstering!
Miles
1998 Black Boxster (owned since 2001)
drbodzin is offline   Reply With Quote
Old 04-18-2013, 05:45 PM   #4
Yeah, electronics is a bit of a hobby...great install Heiko!
This was more because I was bored than anything.
That's the Aux. input in the "ashtray"
Old 04-19-2013, 07:33 AM   #5
BruceH's Avatar
Very nice work!
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 04-16-2014, 01:44 PM   #6
sources for the usb retrofit?
Anyone know if there are these types of USB retrofit plugs out there?
Not to mechanically inclined and do not want to tackle it myself,
thanks
Mike in CA is offline   Reply With Quote
Old 04-17-2014, 09:17 AM   #7
thanks
You can buy the cigarette lighter plugs like mentioned above.
If you want the integrated look using one of the switch blanks like I did, I'll have some for sale within about a month (but much more finished looking than mine). Unfortunately, I'm pretty far behind on retrofits right now.
Old 04-16-2014, 03:54 PM   #8
JayG's Avatar
Great Idea!!
Looks faboo
Where did you get power from?
Old 04-16-2014, 04:33 PM   #9
Heiko's Avatar
Not sure where Particlewave pulled his from, but you can pull it from either the cig-adapter or the main radio feed if you want (those are probably the two easiest to access for 12V). I pulled mine from the switched power on the radio as I run my Garmin off of it and want the jack to go off when the key is turned off. The cig adapter on the other hand is live all the time which would leave the USB outlet on all the time (convenient if you want to keep charging something when the key is off)... In the meantime I've installed two of these now... one for constant power and the one in the dash that's switched - this way I can charge my phone even when I'm not in the car
Great Idea!!
Looks faboo
Previously owned:
Old 04-17-2014, 09:12 AM   #10
Great Idea!!
Looks faboo
Thank you, sir
I pulled power from the phone harness.
Old 04-16-2014, 10:40 PM   #11
2002 Boxster S
Or, you could just stick one of these in your "cigarette lighter".
Mini USB car power adapter
Unless you smoke, in which case you could undo those little screws and use the guts in your installation.
Very cool project, particlewave.
2009 Carrera S cabrio
silver-S is offline   Reply With Quote
Old 04-17-2014, 05:42 AM   #12
Gone
Davev's Avatar
That's the way I did it.
Davev is offline   Reply With Quote
Old 04-17-2014, 09:11 AM   #13
Yeah, but where is the fun in that?
Also, I wanted something integrated and OEM looking, rather than stuck on (or in).
This way, my power port (cig lighter) is always free for other things, too
Old 04-17-2014, 09:50 AM   #14
Gone
Davev's Avatar
But I did lay over a Porsche decal on the cig adapter- and cut out the USB hole. Looks kinda cool.
Old 04-17-2014, 10:43 AM   #15
2002 Boxster S
Davev, you have pics?
Old 04-17-2014, 11:37 AM   #16
I'd like to see this, too. Sounds cool
Old 04-17-2014, 09:30 PM   #17
Gone
Davev's Avatar
The car is down at my winter place but I'll snap one next time I'm down there.
Old 04-18-2014, 01:43 PM   #18
"If you want the integrated look using one of the switch blanks like I did, I'll have some for sale within about a month (but much more finished looking than mine). Unfortunately, I'm pretty far behind on retrofits right now. "
I would be very interested in purchasing one of these usb set ups from you when you are ready to sell them. Please PM when you are ready, ParticleWeave. Thanks
Old 04-18-2014, 09:46 PM   #19
Registered Boxster abuser
healthservices's Avatar
great install...
so where does the heated seat switch go???
Old 04-18-2014, 10:44 PM   #20
Who needs heated seats when you have a heated garage?
FYI: there are also occasionally some empty switch blanks in the upper trim bezels and/or lower "batwing"
I prefer the center console because I don't like charger wires running out from the dash.
