H7 LED Fog Light Replacement
Is it me? Looking at different H7 LED replacement Fog Light bulbs and there doesn't seem to be any standard like conventional 4000K, 6000K etc..
Confusing stuff.. 18 SMD - SMD means Surface Mounted Device 68 SMD 68-SMD H7 LED Bulbs | H7 DRL Replacement Bulbs | H7 LED Fog Light Bulb LEDbulbz : 68 SMT-LED bulb @5000K HID-White...921/906/194/168/w5w/T10 - YouTube 3528 SMD - dimensions 35 x 28 mm 5050 SMD - dimensions 50 x 50 mm The 3528 SMD is a single-chip medium-output LED. The 5050 SMD is a larger, three-chip high-output LED that has approximately 3X the brightness of the 3528. Car Fog Lights - HIDLED - Provide HID and LED Car Lights T |
| All times are GMT -8. The time now is 12:30 AM. |
