Old 08-30-2012, 01:01 AM   #14
politby's Avatar
I ended up using the CD changer bracket; fastened the amp to it using strong double sided tape (the sort used to hang bathroom mirrors on tile walls) and it worked out great.
Unfortunately one of the two threaded nuts in the bulkhead fell down - impossible to retrieve or replace - so the bracket is now held by just one bolt until I figure out a solution.
politby is offline   Reply With Quote
