Old 06-04-2012, 08:24 PM   #1
Changing the color of the LCD dash gauges(freakin awesome!)
Thanks to thstone for the advice!
I used full color led's, some resistors, and a microswitch to do this.
I can choose from 5 colors as of now, and could get the full spectrum by adding a pwm chip. For now, five is plenty.
Colors are blue, green, red, purple, and blue-green(aqua). The pictures didn't show up real well, but I'll post these and get some better ones in the daylight. I think the brightness of the led's combined with the dark interior made my camera's auto exposure go nuts. The focus is terrible as well.
Blue-green didn't look any different from blue in the pictures, but did in person, so I did not include the picture.
Old 06-05-2012, 08:08 AM   #2
Those look good....
Now make them flash red at you when you hit redline.
...or yellow when your oil is low... :dance:
98 boxster
82 280sl parts for sale
feelyx is offline   Reply With Quote
Old 06-05-2012, 08:22 AM   #3
Moderator
Dang, that is pretty nifty. Interesting thing you did.
Old 06-05-2012, 11:13 AM   #4
Thank you for the compliments!
It wasn't exactly plug and play, as you can see, but worth the 3 hour build time.
feelyx, that would be really cool!
Old 06-05-2012, 03:10 PM   #5
bar10dah's Avatar
I second that!
bar10dah is offline   Reply With Quote
Old 06-07-2012, 01:23 AM   #6
Top job!
I wonder if it would fix my mileometer which is slightly pixalated (a common problem on older cars I understand)
PCC010 is offline   Reply With Quote
Old 06-21-2012, 03:28 PM   #7
How difficult was this modification? Do you have detailed instructions?
I have always wanted to add a green RUF style cluster to finalize my 3600S transformation.
2001 Lapis Blue Boxster S Tip (stock), 2001 Guards Red Boxster 5-speed (not very stock)
tightbox is offline   Reply With Quote
Old 06-21-2012, 04:03 PM   #8
Pretty simple if you are handy with a soldering iron. If you just want green, even easier. You will need 3 green leds and a couple 100ohm resistors. Tap two wires into any 12v power source(I just used the existing bulb socket), attach both resistors in parallel to either wire(this will drop voltage to tolerable levels), then mount and wire all three leds(also in parallel).
If you need more detail, just Google "led powered by 12v" to get wiring diagrams.
There are also direct plug and play leds available that you just put into existing socket, no extra wiring or resistors needed, but I don't know if they come in green.
