Old 07-26-2011, 11:17 AM   #1
CEL Codes....been going on for awhile
SO i have had 5 different codes come on for my CEL. I rent to autozone to get a code reader to figure out what they are, and turn it off.
The 2 biggest occurring ones are the P1123 and the P1125
These happen quite frequently and ive just turned them off.
The next one doesn't occur that often but has occurred more than a few times. Its the P0134.
The two other codes have only ever appeared one time each P0410 and P1411
At some point i took it to the Porsche dealer, and they said i needed to replace the Oil Fill Tube. How does this sound to any of ya'll?
Thanks, I have read posts on these codes before, and the MAF cleaning, but i wanted to post my particular issue, maybe the combo of these means something different.
funlovinguy24 is offline   Reply With Quote
Old 07-26-2011, 11:32 AM   #2
Track rat
Topless's Avatar
http://www.renntech.org/forums/topic/628-obd-ii-codes-p0410-and-p1411/
Possible intake air leak (oil filler tube)
Possible SAI issue
Possible failed MAF
Good to get these sorted out. Driving around with these issues can cause long term damage to your motor and cats.
Old 07-26-2011, 11:51 AM   #3
The P0410 and P1411 codes only appeared once, and i turned them off about a year ago and have not come back. Should i still worry about them?
I read the renntech post, and it looks/seems pretty complicated and might be out of my realm
Old 07-26-2011, 03:56 PM   #4
Track rat
Topless's Avatar
No. Only troubleshoot codes that throw a CEL. Our DMEs are very sensitive and load a lot of transient error codes into memory. If the DME adapts or the problem resolves itself the error codes will go away. Once a CEL is lit some diagnosis is needed to solve a recurring issue.
Old 07-27-2011, 09:51 AM   #5
Well that makes sense, if i turn them off, and they don't come back, the problem either got resolved, or was something that was not actually an issue?
Thanks for the clarification. What does DME stand for?
So as of recently i only have the p1123 and p1125 and p0134 codes. What specifically should i do in relation to these? Clean my MAF?
Old 07-27-2011, 12:30 PM   #6
Track rat
Topless's Avatar
Unplug the MAF sensor wire harness. If the car runs better, replace the MAF. Cleaning it is useful if it just got contaminated during a AF replacement but it is still relatively new. If your MAF has more than 30K on it, replace it.
Old 07-28-2011, 07:58 AM   #7
So you are suggesting i drive around with the MAF unplugged, at least for a little bit? Who sells MAF's at a good price?
Old 08-02-2011, 08:19 AM   #8
Also, are there any companys that sell performance MAF's?
I dont knwo if these even exist, but
Old 08-02-2011, 08:30 AM   #9
Johnny Danger's Avatar
Given the codes that are coming up, it wouldn't make sense that it's your MAF sensor . However, if your convinced that it is, you should read this thread .
CEL/Maf Cured
Old 08-03-2011, 08:04 AM   #10
Hmm, so what should i do to cure the p1123 and the p1125
I guess i am getting different information from different people
And thanks for the link, it is quite informative and seems like quite a good deal. Great looking yellow boxster by the way
Old 08-10-2011, 11:47 AM   #11
Followed your instructions, cleaned the MAF REALLY well. It was dirty on some of the connections. Reinstalled. So far no CEL's yet.
Very excited, can already tell a difference in idle, and when i turn the A/C on and pull away from stoplights.
Had fun getting into the engine compartment and putting it back together as well! Very well designed Cars for sure
Thanks guys, lets hope it stays off!
Old 09-13-2011, 06:24 AM   #12
97 Boxster's Avatar
[QUOTE=funlovinguy24]SO i have had 5 different codes come on for my CEL. I rent to autozone to get a code reader to figure out what they are, and turn it off.
Did you say you rented a code reader from Autozone? Didnt know you could rent them if this is the case. I think I am having the same MAF problem as you. Thanks
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
97 Boxster is offline   Reply With Quote
