Old 07-20-2011, 01:51 PM   #1
truegearhead's Avatar
iPod Connection directly in Antenna port
I have a 210 radio which does not have an aux port so I'm thinking about buying the unit below. Does anyone know if Boxsters use the standard antenna port?
http://www.themindfactory.com/Products/PLL-1_FM/PLL-1_Modulator/pll-1_modulator.html
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
Old 07-21-2011, 06:57 AM   #2
sorry, not that type of connector
Old 07-21-2011, 07:08 AM   #3
I picked up a cheap convertor on ebay, we'll see how it works
2003 911 C2
Old 07-21-2011, 03:26 PM   #4
If you car has a cd changer already in the trunk, then this is the easiest plug in to do ... It works perfectly and plugs direction into the back of your radio where you cd changer is currectly plugged and then just plug it into the headphone jack of your ipod. put the radio in cd player mode and your good to go. hope this helps
http://motors.shop.ebay.com/ipodmp34capa/m.html?_nkw=porsche&_sacat=&_odkw=&_osacat=0&bkBtn=&_trksid=p3911.m270.l1313
Life is like Racing, do not hit the brakes until you see God!
There is a fine line between hobby and mental illness.
www.qikqbnboxster.mysite.com
qikqbn is offline   Reply With Quote
Old 07-22-2011, 05:47 AM   #5
Thats the problem, I have an in dash CD player. I have the 210 radio so I don't have an audio input.
2003 911 C2
Old 09-24-2011, 07:45 AM   #6
97 Boxster's Avatar
I have the 210 as well so do we have any options? I don't want to replace the stock radio.
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
97 Boxster is offline   Reply With Quote
Old 09-24-2011, 10:39 AM   #7
Johnny Danger's Avatar
Others may disagree, however, I've had nothing but horrific results trying to use the auxiliary output on the oem radio; especially with one of those cheap eBay knock-off cables . When the vehicle is not running, shunting can occur with regard to electrical/power supply . On three separate occasions, this irreparably harmed 3 of my ipods . You're better off investing in a good quality aftermarket head unit that will provide you with a stable interface .
