Old 06-23-2011, 11:27 AM   #1
Unhappy Drivers Side Window randomly drops 1/4in
Hello Porsche Family,
Drivers Side Window randomly drops 1/4 in on My 2K Boxster while driving...can tap door or press door panel above inside door latch to correct momentarily until it happens again. Culprit - Micro switch, relay, ???
Blackops357 is offline   Reply With Quote
Old 06-23-2011, 12:26 PM   #2
there is a tiny switch in the door handle. You can see it if you pull the handle open. Anyway, either the switch is fautly, or the connection is loose.
pull the panel and check.
part number 99661312500
2002 S
Old 07-20-2011, 11:13 AM   #3
That part in my door handle fell out. So I use velcro to hold handle closed so that the window goes up.
00 2.7 5SPD MT
ProjectM96 is offline   Reply With Quote
Old 10-10-2011, 07:20 PM   #4
Thanks, sorry so late in my reply, I found the culprit (plunger on micro switch) too much play so I wrapped in with plumbers tape.. so far still working. Thank you JHandy for the part number, I am sure I will need it eventually.
