Old 08-26-2010, 10:36 PM   #1
console cubby install help
I had a hifi system in the lower storage unit as shown in the picutre.
I removed the hifi and the slot is empty .
I purchased the lower cubby and I am unable to install it. I tried pushing it in but I am afraid it might break. The top storage is blocking it.
has anyone installed this before ? Do I have to remove the top storage to install it ?
http://www.****************************************************.com/product/shelf986&Category_Code=POTE996IN.html
wysiwyg is offline   Reply With Quote
Old 08-27-2010, 08:51 AM   #2
boxster6354's Avatar
They just snap into place, just make sure they did not send you an upper storage unit as the upper will not fit in the lower space.
If you are sure you have one lower and one upper unit it is an easy process to pull out both and place lower in first, make sure no cables are blocking.
boxster6354 is offline   Reply With Quote
