Old 06-11-2010, 09:00 AM   #1
What's this part?
2001 Boxster
Can anyone tell me what this part is? I have a leak here. See highlighted area in pic. It's the part right under the alternator left bottom bolt. The part is held in place with 5/6 screws. Not sure if it's hydraulic fluid or coolant.
Thanks,
Sonny
sonny is offline   Reply With Quote
Old 06-11-2010, 11:25 AM   #2
do you have a leak there or do you have oil there. Two different things and a picture of your actual motor would help...especially in identifying the substance and source...
Old 06-11-2010, 03:43 PM   #3
someone else posted a pic of that a while ago ,they broke the bracket r+r ing the alt. i believe its part of the cooling system
extanker is offline   Reply With Quote
Old 11-21-2010, 12:12 PM   #4
That part
The area you're identifying is a cover for the engine coolant circuit. You'll want to get it repaired right away. Before the repair you might consider capturing whatever coolant the system might lose, it's re-usable. And don't neglect to replace the gasket!
res1afbe is offline   Reply With Quote
