05-03-2010, 05:58 PM
DIY Subwoofer box that doesn't sacrifice the footwell!
I've been searching for some time for a subwoofer solution but have not been able to find anything I liked, so I decided to build it myself. I was fortunate enough to have 3 Focal 5" subwoofers given to me by a relative, but my design could definitely be modified to fit a shallow mounted 8" subwoofer as well. I found that footwell mounted solutions as well as trunk mounted subwoofers were too intrusive. The seats are not high enough to fit a sub directly underneath, not to mention that the front/ rear adjustment bar would hit a box if you try to use the full width between the seat rails.
My solution: I made a box that mounts the driver behind the seat, but wraps around below the seat as well. This gives the box extra volume (about .33 cubic feet in my case) without making a box that is too deep (restricting rearward movement) or being too high which restricts your seat from reclining. I made the box out of MDF and fiberglass (for the back) and painted it black to match my exterior. Note that I angled the box under the seat which allows the seat to be lowered down somewhat.
05-03-2010, 07:23 PM
Look on renntech.org There is a guy there who builds boxes for a 8". I have one on order from him. A1 quaility...
05-04-2010, 12:37 AM
Is that the rear deck option? I didn't want to give up the storage space because I have the factory windstop.
Also, his is running about 200 watts and mine is running about 500. This option you can make yourself easily. His design also looks more prone to flexing under driver loads.
05-05-2010, 05:13 AM
so how does it sound?
Lov'n my boxster!
2013 Lexus IS350awd
2007 Toyota FJ Cruiser
2004 Porsche Boxster S
05-06-2010, 09:21 AM
and how much do you want to build another?
PM me please.
2001 Seal Grey, 2.7L
05-06-2010, 09:47 AM
Does it limit the movement of the seat???
06-24-2010, 08:59 PM
I also have the stock windstop, but with the bose factory "stuff". No storage for me to begin with, but I have a buddy that says he'll make me one for shallow eights out of fiberglass for $125.
-Jeff-
"I'm a glutton for punishment when it comes to my boxster"
'03 S/ PSS9/ B&M short throw/ EVOMS intake/ NHP full exhaust w/ headers / Cantrell MS custom tune
07-12-2010, 06:00 AM
This is what I have put just behind the seat.
£140 on eBay, £180 in the shops
In Phase USW10 features
* Maximum Power Output 300W
* Rated Power Uotput 100W
* Output Impedance 4 Ohm + 4 Ohm
* Crossover Frequency 50-100Hz
* Size: 270mm (diameter), 69mm (height)
* Weight (inc accessories) 4.8kg
* Phase Button (0-180 degrees)
* Remote level Control (5m)
* Aluminium Cone
* Ultra Slim Design
* Die Cast Aluminium Chassis
05-18-2010, 05:43 PM
Please post the link. I'm interested in seeing what it looks like...
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Audio Controld DQXS (DSP)
05-18-2010, 08:02 PM
I've seen and heard Justin's set up at a PCA event and it's the real deal!
Kind of hard to see from his pictures, but it really doesn't restrict seat travel at all. Great design and the sound really seems to fill the cockpit.
J: I still think it would look awesome if you could cover in factory colored carpet!
For me, I put the biggest Bazooka Tube I could buy in the frunk (10" x 250w Class D Sub). You can definately hear it, but overall I'm disappointed by the end result (unless I'm parked and the hood is up = hardly ever). Plus I often get vibration off the hood and look like a dork at stop lights.
05-23-2010, 09:50 PM
Audio source for sub??
Just wondering where one takes the audio line from to feed the subwoofer amp?
Much thanks.
Don Wilson
Don Wilson
2000 Boxster S
1993 NSX-nicely modified and beautiful
2001 CLK 55
2000 Jeep for camping and astronomy
Craving a new Speedster!
05-24-2010, 08:09 AM
Much thanks.
Don Wilson
You can either use an aftermarket head unit with RCA preouts or you can use a line-out converter from the factory amplifier in the front trunk (sorry I refuse to use the word Frunk).....oh dang I used that word.
Lov'n my boxster!
2013 Lexus IS350awd
05-10-2010, 06:09 AM
Looks Nice But You Still Lost Some Rear Seat Travel
I Had The Same Setup For Years Before Builing A Box For In Front Of The Passenger Seat With Dual 8" Woofers Set At A 45 Degree Angle
The Space Just In Front Of The Seat Is Wasted Space Anyhow. Sit In The Drivers Side And See How Much Room Is Wasted Under Your Legs-unless You Have Really Short Legs Your Leg Just Rests On The Woofer Metal Screens. Lots Of Ways To Cut Bait With This One!!
05-18-2010, 04:53 PM
I did lost about 1.5" on this box, but if you pull the sides in behind the rails, you can do it without losing any room at all. Having said that, I have friends who are well over 6' and they still fit comfortably in this position. I didn't want something visible because then you can attract thieves.
02-08-2011, 11:43 AM
Anyone make a thin single 10 inch sub box for behind the passenger seat?
02-08-2011, 12:13 PM
I would also be interested in something like this.
02-08-2011, 12:34 PM
I was thinking maybe just trying to take a 10 or 12 inch FREE-AIR Subwoofer, mount it to a thin piece of flat wood and just lean it as far back behind the seat.
any thoughts on this?
02-09-2011, 01:39 AM
Bazooka Tube
I've had some great success with a 8" Bazooka Tube in the front trunk. It's different with the bass coming from the front of the car (the pedals vibrate instead of the back of your seat) but it gives me the desired effect ... more bass with my sound system
Pros: I haven't had to build any enclosures or given up any space inside the car and I barely use the front trunk anyway (I still have the spare in there as well).
Cons: unusal bass focus point but def. acceptable.
Wiring up was pretty straight foward because I could ground using an existing ground point and the battery is in the front (for the +ve) . It was a little tricky finding a route through the bulk head. I also had to tighten up some of the trim surrounding the front trunk due to the increased vibration. Rubber washers under the screw points worked very well.
I'll try and take some pics and post.
2001 Porsche Boxster 2.7 L
02-09-2011, 06:34 AM
02-09-2011, 09:12 AM
How much is that custom setup and where is it located in the car? can you take a pic of it mounted in the car bud?
