Old 05-02-2010, 08:09 PM   #1
fox
*HELP* Power Window Switch
Hello gentlemen,
I'm painting my interior... which looks pretty darn good might I add and I need to remove the window switches that don't seem to budge! How do you take them out of the center console removal piece? I've searched and searched
fox is offline   Reply With Quote
Old 05-03-2010, 04:35 AM   #2
Christian H's Avatar
First you need to pull the ashtray out, underneath there are two screws, remove them and the ashtray surround complete with switches should lift out of the centre console,
the window switches are clipped in position and are removed by pulling downwards whilst "unclipping" the tabs that hold the switch in position with a small flat bladed screwdriver.
Hope this helps.
Christian H is offline   Reply With Quote
