Old 07-24-2009, 11:42 AM   #1
elr
Tail Light Replacement
Need instructions on replacing the stock tail lights on a 2000 S with aftermarket LED units.
Thanks,
elr
elr is offline   Reply With Quote
Old 07-24-2009, 01:15 PM   #2
are you looking for what to replace it with or how to?
Here are a couple of links of how to and others mods.
http://wiki.answers.com/Q/How_do_you_change_a_rear_brake_light_bulb_on_porsc he_boxster
http://carltonbale.com/cars/porsche-boxster/porsche-boxster-upgrades/
http://www.usfreeads.com/1335326-cls.html
http://www.kbcarstuff.com/97_04_PORSCHE_BOXSTER_L_E_D_TAIL_LIGHTS_BLACK_p/ltbox97jmled.htm
I'll take my Guns, Religion, and Money; You can keep the "CHANGE" B.O.!!
SO, GROW A PAIR NANCY AND DRIVE IT LIKE YOU STOLE IT!!
http://i826.photobucket.com/albums/z...Main/MyBox.jpg
mptoledo is offline   Reply With Quote
Old 07-25-2009, 06:29 PM   #3
elr
Thanks for the reply. I need instructions how to replace the tail light assembly.
Old 07-25-2009, 07:54 PM   #4
Not much to it: remove the side carpet panels in the trunk by undoing 4 plastic screws ( 2 on each side). Then undo the wiring harness to to each light assembly. Each tail light is held with 4 bolts/nuts. Undo these and the light should slide right out. Good luck.
chaabouni is offline   Reply With Quote
Old 07-26-2009, 06:59 AM   #5
elr
Thanks, I'll give it a try.
