Old 06-22-2009, 05:47 PM   #1
******************************** serpentine belt
Does anyone have any concerns or bad experiences with the serpentine belt offered by ********************************?
Item number : 6PK2115 Description: CRP-Contitech Serpentine Belt/Ribbed Drive Belt
http://i240.photobucket.com/albums/f...r/carlit-1.jpg 2003 Boxster S
spyder803 is offline   Reply With Quote
Old 06-24-2009, 07:46 PM   #2
Well I went ahead and ordered the one above, did I do the right thing? I have right over 40k miles right now and figured even if my current belt is alright having a spare readily available would be a good idea.
Old 06-25-2009, 04:26 AM   #3
Concern: The price, AutoZone has a Goodyear Gatorback cheaper.
Just have to make sure they sell you the AC version of the belt.
But 40,000 seems a little early, I didn't do mine until 60.
My Porsche mechanic drives a Saturn.
'98 Artic Silver w/ Tip
vath2001 is offline   Reply With Quote
Old 06-25-2009, 06:07 AM   #4
why wouldn't you just go with an original belt. I didn't think 28 dollars is overly expensive
http://e-partssales.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=P&Product_Code=99610215166&Category_Code=ENGMECH
01 Boxster - Lapis Blue - Aerokit II Daily Driver.
98 Pontiac sunfire - Winter beater- TRADED IT IN FOR 200 DOLLARS
2010 Honda Civic Coupe - Gunmetal Grey - Lease ended and returned
2011 Mercedes Benz GLK350 - Gunmetal Grey
ramo80 is offline   Reply With Quote
Old 06-25-2009, 08:06 AM   #5
Cuz...AutoZone is 3 miles away. My local dealer is an idiot. And I have had enough OEM stuff on the car break to know that I don't aways want the OEM.
Old 06-29-2009, 06:01 AM   #6
ok I have a belt installation question. When i was doing mine i cranked on the tensioning pulley a couple of times the wrong direction (counter clock wise). Does anyone see that as a problem?? Did i loosen anything while doing that?
Old 07-02-2009, 08:38 AM   #7
Anyone... Help?
Old 07-02-2009, 03:37 PM   #8
No one has answer... drive it and in 100 or 200 miles check it out. And get AAA just in case.
Good luck
Old 07-02-2009, 04:27 PM   #9
no, you're fine - tt's self adjusting. Just make sure when you put the new belt on you get the ribs lined up w/ the grooves on the other pulleys to prevent any unnecessary wear. Also, keep your old belt as a spare in the car (mine's behind my spare tire) just in case you're stuck in the middle of no where. You'll have better luck finding a 15/16 or 24mm wrench in a pinch than you will a replacement belt Mark on it the direction of travel as well.
Congrats on a job well done
