-   -   A couple more DIY Projects are up... (http://986forum.com/forums/diy-project-guides/19410-couple-more-diy-projects-up.html)
ppbon 01-22-2009 05:29 PM
... on my website.
Here: http://www.pedrosgarage.com/Site/DIY%20Projects.html
I also revised the instructions for the Front Engine Mount replacement.
Happy Boxstering,
Pedro
986FortyEight 01-22-2009 07:46 PM
Thanks Pedro! I love the site and have followed many of your guides!
nice one on the spark plug replacement. I did that for the first time last summer and realized then that I would be well advised to replace the spark plug tubes O-rings! Your method is definitely safer than the plier one I used.
One small typo in an otherwise flawless site: "There" instead of "their methods..." in the second paragraph on the tubes.
Mike
blue2000s 01-22-2009 08:56 PM
Quick FYI on the brake fluid DIY: Boiling water doesn't change it's chemical composition. It's still H2O when in gas form.
ppbon 01-23-2009 06:43 AM
Thanks for pointing that out.
I knew that: Solid (ice), liquid (water), gas (water vapor).
Must be that I'm getting old! ;)
I'll make sure and correct it next time I update the site.
Happy Boxstering,
Pedro
ppbon 01-23-2009 06:47 AM
Mike
You are absolutely correct Mike.
Glad you guys are awake and call me on the errors.
Can't get anything past you!
Thanks.
Happy Boxstering,
Pedro
achillian 01-23-2009 10:39 AM
Not sure if the website originally stated "there methods" or "their methods", but "their methods" would be gramatically correct. :cheers:
blue2000s 01-24-2009 07:14 PM
Flushing that clutch line is quite an annoying exercise in dexterity. Thanks for the instructions.
