Old 01-02-2008, 05:24 AM   #1
DIY: Air Filter
Hi all, I have basically given the Boxster it's annual service. I ordered plugs, a drive belt, air filter, oil filter, drain plug washer and fuel pump from Pelican parts in the states. The equivalent parts in Australia cost about $450 AUS, I had them delivered to my door for $220 AUS so was definitely worth getting from halfway around the world.
Parts
1) Open the roof so that its 10cm from the windscreen.
2) Pull these cables off
3) Unclip this black plastic strip
4) Push the roof forward towards the front of the car
5) Remove carpet on top of engine cover
6) Unclip plastic engine cover
7) And one DUSTY engine!
This is a good time to clean and get the dust off it. Also a good time to check the power steering fluid. Mine was low so I had to get a can from the local Porsche dealer.
8) You can now unclip the air filter box and slide the filter and its cradle out.
9) Slide the new filter into the cradle then slide the cradle back into it's spot.
kouks is offline   Reply With Quote
Old 01-02-2008, 07:40 AM   #2
FTD
Fantastic! thank you for the excellent step by step with pics.
Old 01-02-2008, 08:21 AM   #3
Don't forget to look down inside the filter housing and remove any larger debris (like leaves). Good write up with pics!
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
Old 01-10-2008, 06:51 PM   #4
Thank You!
Great post/photos.
It gave me the DIY courage to change out my air filter today too, and it really needed a new one.
The outer layer of foam rubber material was starting to crumble and the filter pleats looked really dirty.
Gary
Seattle, WA
2000 Boxster S
Ferrari 550 Maranello
Subaru Outback DD
SeattleBoxers is offline   Reply With Quote
Old 01-16-2008, 09:01 AM   #5
Great writeup with nice pictures. Are you going to continue on and show us how to change the spark plugs and belt?
2000 Black Boxster S
EVO Intake & GIAC Tuning
Headers & Porsche Sport Exhaust System
ROW M030 Suspension
Front & Rear Strut Braces
B&M Short Shift & EVO Billet Linkage
steve00s is offline   Reply With Quote
Old 01-16-2008, 09:03 AM   #6
Oops just saw it.
Thanks for sharing
ROW M030 Suspension
Old 05-07-2008, 10:36 PM   #7
Cool
Excellent write up!
I have only had my 986 for about 1 1/2 weeks now and I was trying to figure out the easiest way to take off the engine cover and check the engine out from above. The hardest part for me was disconnecting the cables.
I also appreciate the comment you made about the power steering fluid. Sure enough, mine was also low. I will get some soon and fill it back up.
I have had VW's and Audi's but nothing puts a smile on my face when I am driving like my Porsche!
2000 2.7L Boxster, 21K
Litronics
Sport Package
5-speed
Rear speaker system
Harman Kardon Ipod system
Durametric software
OBC Hack
Triple Black
De-snorkled
kurssat is offline   Reply With Quote
