Old 11-25-2007, 09:39 AM   #1
Maintenance Advice
Need some advice on a few projects I am planning/doing.....
First - It is a 1998 base model with 33K miles. It isn't going to be driven much. It is in the garage for the winter now, so I have plenty of time to do projects.
1- Spark plug change. I just did the plugs yesterday. Unfortunately, I should have read some of the threads about anti-seize first. I did put it on all of the plugs. The car is still up on jack stands for other projects. Should I pull the plugs back out a clean off the anti-seize the best I can, or just leave it? I am planning to change the plugs every other year (Driving 3-5K year).
2 - Brake pads/flushing - Next I am going to bleed the brake fluid. The pads look to be OK, but hard to really tell without taking them out. (How do you measure them?). Since I am already going to bleed brakes, should I just replace the pads while I am at it? What is a good source for brake fluid, and how much will I need to do a flush?
3 - Any other things I should do while I am in there? Oil and various filters have already been done. Maybe serpentine belt?
Any advice would be great!
dcompress is offline   Reply With Quote
Old 11-25-2007, 10:51 AM   #2
bmussatti
Guest
Posts: n/a
Your plugs should be just fine.
Changing your drive serp belt sounds like a good idea too. They are about $25.
Maybe take-off front bumper and clean out the rads.
Clean-out all of the drain tubes for the top.
Coolant change.
Trans/gear oil.
Old 11-25-2007, 10:58 AM   #3
Why would putting anti-seize lube on the threads be a bad thing?
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 11-25-2007, 11:40 AM   #4
bmussatti
Guest
Posts: n/a
Adam, this was hotly debated several months ago:
http://www.986forum.com/forums/showthread.php?t=9864&highlight=seize
Old 11-25-2007, 12:49 PM   #5
Wow, thank you. That explains a lot....especially since I plan on checking my plugs soon.
Old 12-22-2007, 05:18 AM   #6
What do they mean by dry torque? I have always put a dab of Mobile1 engine oil on the threads and under the washer before torqueing. Would this cause overtightening?
Also, a 3/8 drive beam style torque wrench is ideal for plugs!
dave944 is offline   Reply With Quote
