Old 10-05-2007, 07:06 AM   #1
Dome Light / Top Latch Issue
I tried searching under many many titles for further information on this topic to no avail so I apologize in adance if this has already been addressed but...
The one piece unit that houses the "dome" light as well as the locking point for the top has decided to "drop in" on me. It appears that the nuts that hold this piece in place are in 3 or 4 parts. Very odd design indeed. I simply cannot get the screws / bolts to lock in! I'm getting really annoyed as I refuse to drive the car in "ghetto" fashion with the piece either removed or hanging down in front of the mirror. Any advice on how I can rectify this annoyance?? Thanks in advance for any input.
Regards,
Larry
Boxster GT3 Guy is offline   Reply With Quote
Old 10-05-2007, 10:51 AM   #2
Can you take a picture? I've taken the housing apart to check the wiring for the bulb when I thought it was loose.
Sain0rs is offline   Reply With Quote
Old 10-05-2007, 11:48 AM   #3
I'll do it tonight and post it in the AM.
LJ
Old 10-05-2007, 03:54 PM   #4
Search this forum for "nutserts." I used this approach and I was quite happy. I think others have used the plastic drywall anchors.
98Boxster98 is offline   Reply With Quote
Old 10-07-2007, 11:50 AM   #5
There are captive brass nut in the windshield for the screws for the visors and the screws for the light. The nuts can split so that they can no longer hold a screw. This is not an uncommon problem.
Pocture is the visor nuts and you can see they have split.
Tool Pants is offline   Reply With Quote
Old 10-11-2007, 08:41 AM   #6
Send a message via AIM to djomlas
happened to mine as well, the nuts split and no longer hold a screw in place.
i used a plastic drywall approach, and its been holding good so far.
http://i34.tinypic.com/157yslk.jpg
"I couldn't find the sports car of my dreams, so I built it myself." ~F. Porsche
Gemballa springs::litronics::Eurotech 18s(275/225)::B&M::MOMO wheel::
exhaust cutouts::EVOcoldair intake::OEM smoked tails & sidemarkers::
colormatched bumperettes::Top Speed Pro-1 exhaust::
my cardomain/pictures page
djomlas is offline   Reply With Quote
Old 10-22-2007, 03:22 PM   #7
Here's a step by step write up on how to R&R them w/ a permanent solution using nutserts as Toolpants notes. Takes about 1.5-2hours to do once you have what's needed.
http://mike.focke.googlepages.com/randrcenternuts
Aside from the web pages, there's a pdf link at the bottom that has more extensive pictures/arrows/details.
Go to it!
Old 10-23-2007, 03:01 PM   #8
great. i just might have to do this afterall...
thx for the link
Old 10-23-2007, 06:18 PM   #9
DJ- definitely do it. Not hard at all - just take your time extracting the old ones. As said, only took about 1.5-2hrs (including photographing most of the steps). Obviously my photography skills aren't nearly as good as yours, but it'll get you where you need to be. PM me w/ any questions.
