11-18-2019, 09:48 AM
So Cal LA area, 2001S for sale, engine has issues
I am looking to sell my 2001S. 169K miles. Los Angeles area So Cal. Major overhaul 30K miles ago, including IMS replaced. Engine has issues so I'm looking to sell it as is. Car starts, idles fine. Possible bearing damage. The rest of the car however is awesome. Newer fully upgraded suspension w/ROW M030 kit. Newer brakes, rotors, calipers rebuilt. Tires in good shape. Upgraded Alpine sound system. Top in good condition and operates fine. Interior spotless, carpet/seats fine. Exterior paint in good shape but nose chips, 6/10. Great project car. Full documentation. Motivated seller. If interested, pm me.
11-21-2019, 01:29 PM
Here are a few additional photos
11-21-2019, 02:31 PM
pity the sheep.
11-28-2019, 09:44 AM
What area bearing do you think it is? Any more info you can share about the mechanicals? Rod knock?
12-02-2019, 07:49 PM
I don't know which bearings or what exactly the issue might be. There is a knock or rattle at start up, which goes away within a couple of seconds as the car idles. The oil light comes on after a few minutes of idling too. The oil light goes away at RPM's over about 1000. Other than that, the car idles fine and smooth.
12-05-2019, 12:08 PM
what is your price?
12-26-2019, 07:14 PM
damn, looks good
12-27-2019, 07:16 AM
Asking $3000?
12-29-2019, 04:58 PM
I bought this car a couple weeks ago.
I pulled the motor. Oil pump looks ok. I'll likely use the heads from this motor and rebuild my other 3.2 with them.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
12-29-2019, 08:35 PM
Who's askin'?
You sure seem to be "collecting"? Haha
12-30-2019, 02:22 PM
Originally Posted by shibeinboxsters
is it a lifter tick problem? mine has been ticking at low idle which disappears at higher rpms. lifter tick seems like it would be cheaper to fix than ur general engine failure, might wanna check that out
I have a good set of lifters all tested & clean I'll sell for $120.
12-30-2019, 04:50 PM
I am starting a Boxster rescue operation😁
