Old 01-03-2023, 04:01 PM   #1
Funracer build
Hi from Germany,
Right now i'm stripping down my 986s from 00.
I'll try to become maximum light without using carbonfibre parts.
Maybe the car can be round about 1100 kg.
Problematic for me is the wirering.
Lot s of no more needed elektrical stuff as navigation, soundsystem, roof, ac....
Is it possible to reduce the cable harness?
And, can i deinstall the psm?
Thanks for reading. Best regards Robert
Robbat is offline   Reply With Quote
Old 01-07-2023, 04:35 PM   #2
You can save 15-20 lbs by reducing the harness. Best way is to remove the entire harnesses from the car, lay them out on the floor, get a factory wiring diagram, and start removing stuff. Very tedious.
P Cars: 1997 Spec Boxster - SPB #94 / 2022 Macan GTS / 2018 Panamera Turbo Sport Turismo ---- Other cars: 2021 F-250 Diesel / 2019 Golf R
Gone: 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches.
PCA National DE Instructor #202106053
nickshu is offline   Reply With Quote
Old 01-10-2023, 08:36 AM   #3
Thanks,
How about Airbags and PSM ?
Will it start without, or may I get in trouble?!
Thanks Robert
Old 01-12-2023, 04:34 PM   #4
yes, you can remove airbags. You can also remove traction control, but you may get warning lights that you can remove.
I've thinned the harness, its an asspain
Old 01-22-2023, 03:16 PM   #5
truegearhead's Avatar
Originally Posted by Robbat View Post
Hi from Germany,
The wiring is the last place I'd look. Here are some easy ones:
-Convert the convertible top to a manual top. Just remove the motors and linkages
-Switch to lighter weight seats (factory seats are pigs)
-install a stainless muffler, the factory one is absurdly heavy. You can easily cut 30lbs here
-lightweight wheels, also reduces rotational and unsprung weight
2003 911 C2
NASA HPDE Instructor
Old 02-22-2023, 03:24 AM   #6
Ok not what the OP asked for, but I must add an easy one: Lighter battery. OEM is a boat anchor...
