Ballast Material
Tom & other racers:
Does PCA allow depleted uranium as ballast? I saw this in a NASA email. Note to self - don't stand next to a NASA car, esp if it glows. 15.20 Ballast All ballast shall be solid metal such as steel, lead, or depleted uranium, and consist of a minimum of five (5) pounds per piece. Each piece shall be bolted in place with through-bolts, fender washers, and a locking-nut / system (e.g. jam-nuts, Nylock, etc.). All ballast shall be secured sufficiently, and all bolts shall be of grade five (5). Nylock nuts or metal crimping lock nuts should not be reused. |
Where would you get depleted uranium? The army-navy surplus store?
Was that someone with a sense of humor? Or do you suppose that's a thing?
Sent from my SM-G970U using Tapatalk |
You can do the math. ;) https://luciteria.com/elements-for-sale/buy-uranium |
50 lbs of lead fits in the large USPS box, "if it fits, it ships" ($17.60). Of course your mailman will hate you.
Order a quantity of depleted uranium online, and you can expect a visit from guys in cheap suits but with good shoes...……………..
If you are a true baller you can get what they use in F1
https://www.tungsten.com/products/tungsten-alloy-race-car-weight/ |
Haha!
PCA does not specify the exact materials allowed as ballast. When I was younger, I worked in the missile industry designing guidance systems, and we always used tungsten to balance the missile airframe. Other more dense materials all have major drawbacks: Platinum is much more expensive, Iridium is fairly rare, and Osmium is poisonous when exposed to air. A 4" cube of tungsten weighs 41lbs! |
| All times are GMT -8. The time now is 07:48 PM. |
