Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster Racing Forum
Old 06-28-2015, 02:37 PM   #1
Caster implications when adding gt3 LCA
Hi folks ...adding some CUP LCA to increase camber to 2.5 or so....what does the caster do and do I need to adjust it? Street car alignment.
I've got the LCA with 2 holes in the caster puck..
Are adjustable tuning forks necessary?
jimk04 is offline   Reply With Quote
Old 07-08-2015, 05:31 PM   #2
LAP1DOUG's Avatar
I have a different LCA than you, but based on my experience, increasing camber with shims in the LCA will drastically effect toe as well as camber, but have little effect on caster.
However, you should be able to rotate the "hockey pucks" around in the LCA to reduce caster using the stock lateral link "tuning forks". This is a good thing as it can allow you to fit a wider front tire without scrubbing the fender liners, which can occur when turning when using the stock caster. Stock caster is way overboard IMHO anyway.
Kippis
986S
991S
Van Diemen RF97
LAP1DOUG is offline   Reply With Quote
