Old 10-09-2012, 04:40 AM   #1
1999 Spec
Not quite there yet but very close. Needs cage and aluminum flywheel. Current weight is 2475 with roll bar extension and no fuel.
S/S brake lines
Hawk blues on front
Hawk HP+ on rear
K&N air filter
Bilstein PSS9 coilovers
Tarret adj. front sway bar
Tarret adj. rear sway bar
Tarret adj. drop links all around
Underdrive pulley
Power steering cooler
Oil pan extension
Aluminum oil pan baffle
Twist on oil filter adapter
Momo aluminum seats
Simpson 5 pt. harnesses
Momo steering wheel
Momo quick release adapter
B&K roll bar extension
16x7 and 16x9 wheel set
17x7 and 17x8.5 wheel set with Nitto nt-01 tires, 4 heat cycles
Gt3 front brake ducts
Shift light indicator
Gt3 front adj. control arms
400/500 springs
adj. rear toe links
wheels studs
emergency cut-off switch
Boxster S oil cooler
12 lb battery
Hood pins front and back
$16,000
If interested email and I will give you my # and we can talk. Bill, Pgh, PA
wmtee is offline   Reply With Quote
Old 10-09-2012, 11:18 AM   #2
SPB racer
Wow! That is a hell of a good deal if the car is in halfway good shape. Another few grand and you have a Spec racer.
Jittsl is offline   Reply With Quote
