Old 02-19-2007, 04:48 PM   #1
Driver side threshold**updated with shop manual links
I have an 02 base and I am trying to remove the driver side (and passenger I suppose) factory threshold/sill which contains only the front and rear trunk release switches (I don't have the seat memory option).
I can see that on the inside of the threshol/sill there are two plugs. Once removed I can get the tip of a screwdriver in there but can necessarily "feel" a torx head. I know it has to be ther but does anyone have any idea what size it is??
I am trying to remove it so that I can refinish it. It seems the previous owner had a habit of dragging his/her feet across it causing the rubberized finish to peel. Underneath I can see black plastic, the same color as the original finish. I'm either going to peel the rest of it off and leave it, or paint it a flat black color.
Thanks,
Jeff
jl1252 is offline   Reply With Quote
Old 02-20-2007, 09:16 AM   #2
I found it here: http://www.cannell.co.uk/Boxster_Manuals/
I ended up d/l'ing all of the items on this page. I'm sure thy will come in handy one day.
Thanks,
Jeff
Old 02-20-2007, 09:41 AM   #3
cool
thank you very much
BobMarley1 is offline   Reply With Quote
Old 02-20-2007, 09:50 AM   #4
That looks important enough to be a sticky. Just my opinion.
aren040 is offline   Reply With Quote
Old 02-20-2007, 10:01 AM   #5
I originally found that site by going to this site: http://www.porscheteam.nl/werkplaats/handboeken/handboeken.html
It is mostly in Dutch, and says the links won't work unless you use Mozilla Firefox. So, I fired up the Linux computer and Viola! all the links worked. I then just decided to direct my Widows computer to the hosting site (the www.canell.co.uk/Boxster_Manuals/) and found that directory. The site has manuals for tons of Porche models.
I hope that helps.
Jeff
PS found some others that might be helpful. Maybe an admin could comment on wether or not there are any issues woth poisting these, but in the mean time...
1972-89 911 Workshop Manuals: http://www.cannell.co.uk/911_72-89_Workshop_Manuals/
993 Workshop Manual: http://www.cannell.co.uk/993_Workshop_Manuals/
996 Workshop Manuals: http://www.cannell.co.uk/996_Workshop_Manuals/
944 Workshop Manuals : http://www.cannell.co.uk/944_workshop_Manual/
968 Workshop Manuals: http://www.cannell.co.uk/968_Workshop_Manuals/
928 Workshop Manuals: http://www.cannell.co.uk/928_Workshop_Manuals/
