Old 02-15-2007, 09:31 PM   #1
Talking dont want to hijack the "corner" thread
Okay, got my flame suit on before I get bombarded by "You don't know how to drive a stick question or Manual is better than tip comment"
How to use the tip's in the corners? Can you shift 2 gears down with a slight tap or pressure on the brake and pull an upshift as soon as you clear the corners? For short, can you enjoy a tiptronic on twisties or on AXross ?
Can someone tell me a proper way of using tiptronic in twisties
thanks in advance, guys
unklekraker is offline   Reply With Quote
Old 02-16-2007, 06:55 AM   #2
Send a message via AIM to Travis
All I have to add is . . . . . . . .
Travis is offline   Reply With Quote
Old 02-16-2007, 07:01 AM   #3
whew...thank God i got my flame suit on..hehehehehehehe! i found out on the other forum (AX/DE instructor) that all I have to do is put it in sports mode and all i have to worry about is downshifting it
Old 02-16-2007, 07:03 AM   #4
I didn't want to hijack his thread either... but
'how do you attack a corner?'
WITH MY NINE MIL, BABY!
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
http://www.zoto.com/frayadjacent/img...f27a-4a399.jpg <---- my car. ^ crap I post.
"The existence of the flamethrower is evidence that someone, somewhere once said 'I want to set those people over there on fire, but I don't want to have to walk over there to do it.'"
FrayAdjacent is offline   Reply With Quote
Old 02-16-2007, 07:12 AM   #5
i knew this was coming...i was going to qoute, press the left button of the controller to zoom in and the same time your thumb is holding the x button to aim as your right pointer finger is tapping the top button of the controller...but that one would only work on Halo II..hehehehehe!
Old 02-16-2007, 01:15 PM   #6
Although I have read about the brake application theory, I've never practiced it so i can't comment.
The good thing about the tip is you can't overrev it. The computer won't allow a shift if it will cause you to overrev the motor.
In the examples where I've driven a tip (AX and DE applications):
1) I left in full automatic mode because, specifically because I wanted to "simplify" things. Worked fine
2) Used the steering wheel controls for downshifting while braking for a corner. Then used the controls for upshifting as needed.
I think in #2 is how you could best enjoy the "manual" features of the tip.
To say you must downshift before and upshift after every corner is to broad a statement. Some corners, absolutely. Other corners? maybe not.
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
racer_d is offline   Reply With Quote
