02-06-2007, 06:43 AM
Car continues to stay on after key is removed? (key switch problem?)
So I just got to work today (I'm in central PA where it is officially an Ass-Cold -8 degrees in the morning). When I went to get out of my car, the engine stopped, but the car itself never turned off.. The stereo and everything attached to "accessory" line on the key switch stayed on. Has anyone else had this happen to them? It seems to "stick" on more in cold weather, but it normally turns off when I close my door. Today it did not.
Edited to say that this is a 97 986 with 90k miles on it. Forgot to include that, sorry!
02-06-2007, 07:07 AM
Sounds like your ignition switch is going/gone bad - very common problem. Easy DIY and about $25 in parts.
02-06-2007, 07:29 AM
Is there any better place to get the switch than at the dealer?
02-06-2007, 07:44 AM
Thanks for the link, I've got one on order...
Edit: Wow, that really sucks.. I haven't had anything too crazy happen to me because of it.... yet.. Either way, I hope it doesn't take them too long to get it to me, since they're in CT, it's only a few states over.
Thanks again!
02-06-2007, 07:57 AM
Originally Posted by RandallNeighbour
After you installed the new switch, does your key need to me jiggled a bit before the key can turn? Mine sometimes needs abit of jiggle to go into the on position and sometime it just turns with ease. Is the new one like rotating a a philips screwdriver through butter?
02-06-2007, 08:08 AM
After my new one was installed, it turns fine and there's no jiggling or fiddling with it. It may not have been installed correctly, or your new one has broken already.
They are made of cheap plastic and do break. My mechanic keeps a half dozen of them in his toolbox for the inevitable day that every single 996 and 986 customer of his calls and says that mysterious things are happening with their electrical systems.
02-06-2007, 08:11 AM
Ah ok, good stuff. I havent had one installed before but i think i might have to give it a whirl and install it. Is there a DIY writeup on the forum?
02-06-2007, 09:34 AM
CJ, I can't find a writeup, so i'll take some pictures when I do mine.
Randall - KRICKEY! That guy (foreigncarpartsonline) ships fast! I ordered it when you posted the link (10:40), and I just recieved confirmation that it's shipped... That's a two hour turn around time.. Awesome!
Thanks again!
02-06-2007, 10:56 AM
Here's a link to a write up
Wonko-
Save your write up time for driving. Here's a link to one already done. The part #s may have changed since this was written, but the procedure is the same - EXCEPT you should not need to remove the drivers seat - just contort yourself like hell to get up in there. Good luck!
http://www.industryfigure.com/berkeley/Porsche/ignitionswitch.htm
BTW, with the really cold temps and a bad ignition switch, it's a good idea to throw your battery maintainer on the car until you fix the switch.
Here's a one page write up w/ out as much details, but again, good 'nuff (courtesy of Tool Pants on RennTech)
02-06-2007, 11:27 AM
Thanks Burg... I'll use the time to throw down the top and go for a spi..... . oh, wait, no, it's bloody cold... I'll use the time to sit inside and wish it was warm enough to throw the top down to go for a ride
02-06-2007, 11:42 AM
I have an 02 where I just noticed that the raido stays on for a couple of seconds after the key is withdrawn, then cuts off. I think this is normal. What I think is not noraml is that I can turn the radio back on without the key in the ignition. Any thoughts? I wasn't trying to hijack, the issue is similar as the original poster. Sometimes I too have to jiggle the key once its inserted into the ignition to get it to turn. Should I replace the ignition switch?
jeff
02-06-2007, 01:03 PM
the radio can be turned on while the key is out...that is normal.
02-06-2007, 01:27 PM
Thanks for replying. That is good to hear. I guess I'll wait till I have other symptoms before I replace the ignition switch.
Jeff
02-06-2007, 03:30 PM
Wonko, where are you in "Central Pennsylvania"? I'm near State College/Bellefonte.
02-06-2007, 08:43 PM
Paul,
I live in Bellefonte! Sounds like we'll have to have a P-Car meetup  shoot me a PM if you want to meet up somewhere... are you a member of the Porsche Club of America here? I got information when I bought the boxster a few months ago, but I haven't sent in any paperwork yet...
~Aaron
02-07-2007, 03:55 AM
tread title
i almost choked when i saw the tread title. " car continues to stay on after key removed" I thought you meant car engine stays on when key removed.
02-07-2007, 05:22 AM
yeah, I thought that might be confusing... but I did a lot of searches before I posted the new thread, and I basically try to put all the words I searched for in the title
02-07-2007, 05:34 AM
In PA as well... just had this happen for the first time the other day. Parked in the garage, took the key out, cd kept playing after I closed the door and locked it. Starting and stopping the car again resolved it. The next day the car wouldn't lock from the key button after I got out. Started, stopped, worked fine.
Neither of these issues have repeated themselves.
02-07-2007, 05:49 AM
Fishage - That's EXACTLY what happened to me.
