Old 01-27-2007, 05:10 PM   #1
door window regulator prob
For whatever reason, my door window regulator just decided to stop working today. I tried the Bentley's reset solution with no luck. Any advice?
jsmithdmd is offline   Reply With Quote
Old 01-27-2007, 05:40 PM   #2
http://forums.rennlist.com/.... look up "window problems" and you will see my post with my rennlist name "clb0099". It could be the regulator,motor,or the fact of wires getting corroded... you can eve look up all my posts . I had both windows replaced new regulators and new wiring harness. I hope this helps
clb0099 is offline   Reply With Quote
Old 01-27-2007, 05:45 PM   #3
If you don't mind me asking, how much did that run you? Did you go to the dealer or an indy garage?
Old 01-27-2007, 06:19 PM   #4
well here is the short answer... 320 for labor per side for replacing wires. The wiring was another 165.00 since i did not going with the complete wiring harness update but just the wires and connections. So it was 640 labor for the doors and 230 for the parts. The regulator for both sides i bought from ebay which were 160 from a crashed 2002 boxster and i bought new motors also from ebay which cost 120. The regulator you can change out yourself very easily maybe 2 hrs of work . The wires i would not even attempt since there is like 43 wires. There is a write up on replacing the regulator on rennlist i believe . I hope this helps
Old 01-27-2007, 06:20 PM   #5
don't have either of those I use msn messenger
Old 01-27-2007, 06:21 PM   #6
It does help! Thanks.
Old 01-27-2007, 06:21 PM   #7
i will use my wife's account eurspice@aol.com on msn
