Old 01-10-2007, 08:12 AM   #1
Help please!
The battery of my car keys had enough juice for me to lock it this morning but now the batteries are dead. I haven't tried it yet but will I be able to start my car by just unlocking the car with the key? There's a light that's blinking in the upper middle part of the dash and I'm not sure if this is an alarm system or what.
2001 Lapis Blue Boxster
http://i123.photobucket.com/albums/o...asa/ebcomp.jpg
jmabasa is offline   Reply With Quote
Old 01-10-2007, 08:23 AM   #2
I'm able to unlock mine and make it run with the valet key (which has no electonic devices) so there's no reason it shouldn't work. Make your first trip to Kraggen to get that new battery!
Bobby
http://i89.photobucket.com/albums/k2...4/CIMG4210.jpg
Triple black '02
Tinted ambers
18inch Turbo Twists
British Flag!
johnsonrj74 is offline   Reply With Quote
Old 01-10-2007, 08:52 AM   #3
yes, the flashing light is the alarm. once you open the door manually with the key, you have 10 seconds to start the car or the alarm will sound. if alarm sounds, just start the car and it will stop. it sounds like your key battery contact is weak or faulty. some people cut "squares" of ziplock plastic and place several "layers" of plastic inside the key head to improve battery contact. give it a try. anyway, your key can still manually open the door and start the car. new key head at dealer is expensive and requires programming (around $200 or so total).
porschedude is offline   Reply With Quote
Old 01-10-2007, 09:07 AM   #4
Thanks to the advice everyones given so far. I just came from the dealer and got a couple of batteries. The light on the key flashes now but it wont lock or unlock the car. I tried other suggestions like putting the key into the ignition but not starting it, taking out the key and pressing the lock/unlock button within a few seconds but nothing. Is there any other way I can get the keyless entry to work or am I stuck now with just locking/unlocking the car manually?
Old 01-10-2007, 09:18 AM   #5
I suspect that you may need to get the Dealer involved. The Alarm/Immobilizer is adjusted, programmed by the PST2 Computer at the Dealer. They can tell you what's going on.
But first, does your alarm work when you arm it manually? If not, there is a 10A ATC Fuse in the Immobilizer Module under the Driver Seat. Be sure this fuse isn't blown.
Another possibility is that the Alarm went into Sleep mode (after 120 Hrs. of non-use, the module stops listening for the key as a battery saving feature). Your Key Fob battery may have died and the car went into Sleep Mode. If you change the battery it still will not work until you once open the Lock manually and then switch on the Ignition and/or Start the car. Try that and see if it doesn't correct your problem. Hope this helps...
Happy Motoring!... Jim'99
Old 01-10-2007, 10:00 AM   #6
Hi Jim! The alarm will arm manually with the key. And the battery just died this morning so I doubt it went to sleep mode. I just started the car now and drove it around but the remote still wont work. Any other ideas how to make it work? Thanks!
Old 01-10-2007, 10:12 AM   #7
Get Thee to the Dealer... sorry...
Old 01-10-2007, 12:38 PM   #8
The dealer said that once the battery goes dead, the remote of the key will no longer be of any use because the programming in the key will be erased and that the only option is to buy a new key and have it programmed. Any truth to this?
Old 01-10-2007, 12:49 PM   #9
My goodness.. you might have to lock and unlock the car with the actual key and not the remote? Take a day off from work due to all the stress that is sure to build up Just joking.
As mentioned, the key fob will not interfere with the key actually starting the car. As for any reprogramming of the fob once a new battery has been installed, sorry I can't help. Maybe hit the "ctl"+"alt"+"del" keys
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
Old 01-10-2007, 04:28 PM   #10
I don't believe you would need to buy a new key also. if they can program a brand new (and expensive - $200) key to work with your current car alarm then they must be able to re-program the old one!
Bobby
Triple black '02
Tinted ambers
18inch Turbo Twists
British Flag!
Old 01-10-2007, 04:36 PM   #11
They did say that to be able to reprogram the old one, you would have to have the code that came with the key. Not sure if I can still find that one though. I got a quote from the dealer quoting me over 300 bucks for the new key plus programming it. Any suggestions where I might be able to get it cheaper?
Old 01-10-2007, 04:46 PM   #12
Send a message via AIM to Travis
I took mine out to replace to find I had gotten the wrong battery, left it out and went to the store a few hours later to pick one up. I had no issues when I put the new one back in.
Travis is offline   Reply With Quote
