Old 01-22-2026, 02:29 PM   #1
oldbadger's Avatar
interior compartment stuck open
Topic: Standard Boxster
Interior compartment behind seats. shoulder high, accessed by two sliding doors, both open from center to outboard.
Problem: port side sliding door is open and stuck, maybe past a detent. It does move a little. I would like to be able to close it and don’t want to force it. Are there any suggestions from any of those who have lived with a standard Boxster longer than I have?
Thanks for any help.
oldbadger is offline   Reply With Quote
Old 01-22-2026, 03:11 PM   #2
The entire bottom of the rear shelf storage is open. Remove the rear shelf by undoing the top fasteners lift it up and you should have full access to the track.
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is online now   Reply With Quote
Old 01-23-2026, 03:07 AM   #3
Registered Member
Might makes right, in this case. I had the exact same problem a few years back.
I removed the assembly, took it apart as much as I could (which wasn’t much), and in the end, just pulled really hard on it, and it broke free.
I could have, and you can, do the same thing with it still in the car.
Tom Coradeschi
03 Boxster
tcoradeschi is offline   Reply With Quote
Old 01-23-2026, 12:58 PM   #4
Multi-Boxer Driver
Deserion's Avatar
It’s the steel reinforcement rods that loosen and block the door tracks. Once they’re back in place the doors work as usual.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 01-25-2026, 03:39 PM   #5
oldbadger's Avatar
reply
A person more knowledgeabel than I manipulated the track behind the offending door managed to get the door to close. All is well,
Thanks for all the attention.
Old 01-25-2026, 03:41 PM   #6
oldbadger's Avatar
final fix
A person with more knowedge than I have manpulated that track behind the door allowing the door to close.
All is well, thank you for your attention.
Old 01-26-2026, 02:29 PM   #7
Same problem on my '99. I think a little epoxy was all that was needed to secure those little rods.
Ted Crilly is online now   Reply With Quote
