Old 12-10-2025, 07:41 AM   #1
AOS replacememt
I am replacing the AOS on my 02 986 S. I bought a replacement from Porsche dealership. Do I need an extended line that feeds into AOS? I heard the design changed do the line might be to short?
Thanks.
Old 12-10-2025, 09:01 AM   #2
I had read that too but I was able to replace the AOS on my '98 using the existing line (which is good as the replacement is kind of pricey).
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is online now   Reply With Quote
Old 12-10-2025, 07:47 PM   #3
DWBOX, perhaps is a good time to replace the accordeon hoses as well, since these age and become very brittle I know means more expense but that way you will not have to do the job twice..
The accordeon hose that goes to the top of the bank 2 is accesible by removing the cover behind the seats and you don't have to remove the intake plennum
Old 12-11-2025, 05:45 PM   #4
I’ll will look into, thanks. Do you have a picture of the part?
Old 12-11-2025, 07:35 PM   #5
Sorry, I don't.. but the AOS has two plastic 'accordeon hoses' a short one that connects the AOS to the hose right next to the throttle body and a long one connecting the AOS to a valve in top of the cylinder head (#4..?) right behind the driver seat.
These hoses are thin walled and will dry up with time (and heat) and become very brittle, let me try to find a P/N for you.
EDIT: The hoses that I am talking about are included on this kit
https://www. f c p e u r o.com/products/porsche-engine-air-oil-separator-kit-vaico-99610702602kt
P/N Porsche /VNE 99610702602KT (remove spaces)
Old 12-12-2025, 11:41 AM   #6
The updated AOS should still work with your original hose on an ’02. Just check the breather tube and lower hose for cracks or stiffness, as many people replace them due to age rather than length.
Pringle86 is offline   Reply With Quote
Old 12-14-2025, 09:43 PM   #7
Multi-Boxer Driver
Deserion's Avatar
Putting this out here for info only (because I have it on my 996 and I’m a huge fan).
https://ultimateaos.com/
https://lnengineering.com/products/parts-and-upgrades-for-porsche-boxster-cayman-and-911-engines/the-uaos-ultimate-aos/the-porsche-987-ultimate-aos-uaos-al-complete-kit.html
Not paid, just a very pleased customer. I have this on my 996 and I believe he has it for the 986 as well. Makes any future PCV changes a breeze, and the track kit will drain any accumulated oil back into the crankcase. I’m running 2qt over on my car.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
