-   -   hazard flashing LEFT SIDE ONLY (http://986forum.com/forums/boxster-general-discussions/87439-hazard-flashing-left-side-only.html)
gbp808 09-09-2025 02:57 PM
Has anyone come across one-side-only hazard "alarm" flash? My left side comes on and goes away randomly. It happens even when parked without any touching of the the things that i believe can trigger a both-side hazard flash (roof, doors, windows, locks, trunks etc) Well i do open the door, but no locking, windows are fully down)
Not sure whether to treat as a "standard, both side" intermittent hazard alarm, with a hazard display issue, or if there is a different rabbit hole for one side only?
I was getting a both-side hazard until I fixed the shorting circuit board for the power lock on the right.
Could this left-only hazard indicate a left side door problem? It is not displaying any symptoms.
Also the alarm horn was disconnected by the PO and out of respect for my neighbors I have not reconnected, yet.
Looking fwd to thoughts
thanks
997_986 09-10-2025 05:20 AM
My money is on the relais or its connection, 91461830312. Should be the third from left on top.
