Old 08-20-2025, 11:41 AM   #1
Passenger window 'twitching' up and down
My 1998 2.5 Boxster has developed an issue whereby when the passenger side window is fully up or near the top of the window frame, is starts 'twitch' up and down only slightly (maybe a few mm) but very quickly and repetitively until it drains the battery.
The only way I can seem to stop this from happening is to put the window down a bit which means I can't leave the window up when out, parked, or in the garage. Does anyone know what might be causing this and if so, what I need to do to stop it? I imagine it might be a faulty switch somewhere. The windows also do not drop anymore when the roof latch is released.
Thanks in advance for any help.
somerled is offline   Reply With Quote
Old 08-20-2025, 05:29 PM   #2
On boxa.net there was mention of on page 29 owner's manual instructions on how to reset the window settings. Tried those?
Old 08-20-2025, 06:38 PM   #3
elgyqc's Avatar
Read through this thread...
https://986forum.com/forums/boxster-general-discussions/87381-possessed-door-latch-01-box-s-rt-side.html
... might help.
Grant
Old 08-20-2025, 07:25 PM   #4
That is your door latch microswitch (although possibly the door handle switches as well). Basically, when you open the door, there is a switch on each handle (interior and exterior). This tells the window to roll down a smidge. It stays down until the microswitch in the door latch tells it the door is closed. This allows your door to close without the window smashing the frame.
What has happened is one of the microswitches is worn, and it is bouncing "open"/closed, causing this.
Do you have a floppy door handle? If you open the door, and leave it open does the window stay down?
I'd be inclined to suspect door latch - they are a common failure point.
maxbottomtime is online now   Reply With Quote
Old 08-23-2025, 06:39 AM   #5
Thanks very much for the message. It's odd because the slight window drop function (when the handle is pulled) hasn't worked for years but the window seems to be seated to both avoid the frame when closing, and to stop any ingress of water/rain. So the twitching is odd because that function hasn't even worked for a long time. The window drop on the right hand side works but the window is seated too high so hits the frame when closed.
The passenger door handle does not seem floppy. If I oped the door, the window remains in place no matter whether up or down. Is replacing the door latch microswitch DIY-able for someone with basic skills and tools? Thanks.
Old 08-24-2025, 05:08 AM   #6
Registered Member
You will need to replace the entire latch assembly, sadly. It’s not particularly difficult, but it is rather expensive, considering that the only piece which has failed is far from that.
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
