Old 08-07-2025, 10:15 AM   #1
Long crank before start
Having a new quirk. Car is cranking a while before it starts. Doesn't matter hot or cold, but seems to be if it's sitting long enough to bleed fuel pressure.
When I turn the key "on" I don't think I'm hearing the pump prime... Unsure why this would be. I'm going to check the relay and see if it's getting a signal.
Once it does start it runs great, no issues. No associated codes.
I did have the brake booster line break off the manifold. I repaired that, fuel trims are within range so I don't suspect a vac leak.
Any other suggestions?
Mangosmoothie is offline   Reply With Quote
