Old 08-04-2025, 08:25 PM   #1
Drive shaft CB joint grease
By any chance someone knows the specs of the grease used on the driveshaft boots?
One of my transmission side boots is leaking, I already have the 'ottinger type' clamp but before I replace it, I would like to try to replenish the boot with the grease that now is laying everywhere close to the drive axle.
PS: I am planning on buying a grease srynge to push the new grease throung the edge oif the rubber boot before I instal the new clamp, thank you in advance!
Old 08-05-2025, 06:25 AM   #2
High-quality, high-temperature, molybdenum disulfide (MoS2)-containing grease. Porsche recommends a specific grease (part number 000 043 305 45), but other options from reputable brands like Red Line, Liqui Moly, and NEO Synthetics are also highly regarded.
Old 08-05-2025, 07:12 AM   #3
Moderator
Can’t help with the grease recommendation, but tell me about the “ottinger type” cv boot. Did you find one specific to our cars, or are you adapting one from a different vehicle?
Bill Ladd is online now   Reply With Quote
Old 08-07-2025, 05:54 PM   #4
JFK, thank you for the grease recommendation, I would like to get the same brand (even from the dealer) to avoid mixing different grease brands.
For some reason, I keep thinking about the Alaska MD80 that crashed off the coast of CA, the accident report blame the accident to over extended maintenence and also because the mechanics use a different kind of grease that was not compatible with the one on the jackscrew, the new grease mix ended acting as a sand paper that wore the treads of the jackscrew very quickly causing the assembly to fail.
In my case, the car had 40k miles and I would like to prevent premature wear on the CV joints.
Bill, I bought the ottinger style clamps (not the boots) from F C P Euro.
Old 08-08-2025, 05:56 AM   #5
Moderator
Ah, clamps. Need to up my reading comprehension skills. Thanks
