Old 07-19-2025, 05:16 PM   #1
jackfor
Boxster 986 Engine mount center
If you buy only the center of the engine mount be prepare to go to a shop to switch the old one for the new one. It's a press fit and you need a press and pipes of the right size to do the job.
jackfor is offline   Reply With Quote
Old 07-20-2025, 02:02 AM   #2
Not necessarily. If you have a vice that can be extended long enough, you can also do this with a ring turned to 73.3 mm outside diameter (inner diameter depends on your mount, normally 50mm+) and a sufficiently large counter. But a press is more elegant.
997_986 is offline   Reply With Quote
