Old 07-13-2025, 04:52 AM   #1
How easy to fit 98651463402… small trim piece
Mines got ‘spider corrosion’ I could rub it down I guess but new ones ex ‘design911’ aren’t crazy money about £18. It’s the small metal strip directly behind the door, black colour. It is shown in the attached image ‘toothed’ looking piece at the bottom left of the image no 14. Or I could rub it down and delicately paint.
Part number 14 picture set 811-13
https://www.design911.com/uploads/images/diagrams/diagrams/986_2004_8_11_811-13.jpg?width=545&height=628
Can’t upload a picture. Can anyone help me on this one?
Triops is offline   Reply With Quote
Old 07-13-2025, 08:50 AM   #2
why replace #14 when all you can see is #16?
2003 Boxster S, Chevy LS3.
obthomas is online now   Reply With Quote
Old 07-13-2025, 09:46 AM   #3
The Radium King's Avatar
#14 part is totally visible. iirc #16 pops off to expose two rivets that hold #14 to the chassis. riviets need to be drilled out to replace #14. and new rivets when done.
Old 07-13-2025, 12:12 PM   #4
Because it looks like you have to slide “16” off to get at the “14” which gets riveted in place as per the diagram on the design911 website. My concern is getting the cover plate “16” off without damaging the fixing points.
Old 07-13-2025, 02:01 PM   #5
to repeat - 16 pops off. the assembly is designed to connect the porsche roof rack system.
Old 07-13-2025, 03:00 PM   #6
Has anyone popped this item “16” plastic trim cover off to get at the rivets without destroying it?. Is it possible to get it off and replace it without buying a replacement??
Old 07-13-2025, 06:08 PM   #7
buy a sharpie and colour it in.
Old 07-14-2025, 01:02 AM   #8
So it sounds like you’ve done this job. Did you get 16 off without problems and was it re-usable or did you have to buy and paint a new one?
Old 07-14-2025, 04:49 AM   #9
78F350's Avatar
It's been a while since I pulled them off, but I don't remember it being difficult. Pretty sure I carefully pried it slightly inward, then up with a plastic trim tool. Note the small lip on 16 that tucks under 14.
Old 07-14-2025, 03:33 PM   #10
Great, thanks for your help.
