Old 06-18-2025, 02:38 PM   #1
‘Dead spot’ at WOT from 4500-6200 RPM
Recently I have been experiencing a lack of power at WOT from 4500-6200 RPM.
It feels like the Variocam is kicking in 1700 rpm later than it should.
Based on the codes I suspect this is a vacuum leak, but wanted to check with the wisdom on this forum.
Codes:
P1124 oxygen sensing adaptation range 1 (cyls. 1-3) at enrichment limit
P1126 oxygen sensing adaptation range 1 (cyls. 4-6) at enrichment limit
P1128 Oxygen Sensing Adaptation Area 2 (cyls. 1-3) - Rich Threshold
P1130 Oxygen Sensing Adaptation Area 2 (cyls. 4-6) - Rich Threshold
Camshaft deviation is 0 for bank 1 and -3 for bank 2
1998 Boxster 5 speed/2.5L
56k miles
Car has test pipes (track)
Should I go chase down a vacuum leak or start elsewhere?
98 Arena Red 986
Stroked & Blown is offline   Reply With Quote
Old 06-18-2025, 11:51 PM   #2
When my MAF sensor started acting up it felt like power dipped around 4500-5000 and then surged after that. That could be another place to start.
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is offline   Reply With Quote
Old 06-21-2025, 05:52 AM   #3
Thank you - removed the maf and cleaned it with some CRC MAF cleaner. Problem solved.
98 Arena Red 986
