Old 06-06-2025, 03:21 PM   #1
Dave80GTSi's Avatar
Modifying Front Fender Liners For Better Cooling
Has anyone done this:
https://www.pelicanparts.com/techarticles/Porsche-996-997-Carrera/107-BODY-Modifying_Your_Wheelwell_Liners/107-BODY-Modifying_Your_Wheelwell_Liners.htm
At first glance, seems like a good idea.
Any downsides?
DM
2000 Ocean Blue Boxster S
1980 Ferrari 308 GTSi
2019 Alfa Romeo Giulia Ti Sport AWD
Dave80GTSi is online now   Reply With Quote
Old 06-07-2025, 04:28 AM   #2
"50 Years of 550 Spyder"
10/10ths's Avatar
It’s more trouble than you think….
……also, the airflow out the bottom of the radiators on our cars is really great. As long as you have those two rubber flaps on each side, you get a huge pressure difference on both sides of the radiators.
If you want more cooling capacity, just install the double core, all aluminum CSF radiators.
10/10ths is online now   Reply With Quote
Old 06-07-2025, 04:32 AM   #3
I think there’s a good reason for the top vents on the GT3 bumper cover having experienced a bit of float over 100mph on the track with my Boxster. Although, oddly, my 997 doesn’t feel so bad.
-H. L. Mencken
Old 06-07-2025, 04:35 AM   #4
10/10ths's Avatar
Oops….
…..I guess I should have read the link first, this is to improve brake cooling.
I installed the bigger GT3 brake cooling vanes on the control arm. I don’t k ow if that helped either.
I have an “S” with the bigger brakes, and when running the Porsche Sport pads, I’ve never run out of brakes at DE events.
Old 06-09-2025, 08:15 AM   #5
The Radium King's Avatar
997 vents into the wheel wells like the mod.
https://www.pelicanparts.com/More_Info/99750412400.htm?pn=997-504-124-00-M100
i presume if good enough for porsche to make the change then it's a good thing to do.
Old 06-18-2025, 01:51 PM   #6
Doing this right now. Even with the proper tools, some of these plastic rivets are tough. I’m about to go nuclear and melt them off with the heat gun! It’s good to do this as there’s a good load of crap in the radiators again.
-H. L. Mencken
Old 06-19-2025, 03:29 AM   #7
Registered Member
Originally Posted by Dave80GTSi View Post
Seems like a lot of work - is this car tracked and are you having brake fade issues?
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
Old 06-19-2025, 04:22 AM   #8
Yes, I noticed the "floaty" feeling at the track.
I do have the GT3 brake scoops (bought back when they were $6!!) and have not had any fade issues.
-H. L. Mencken
Old 06-19-2025, 01:37 PM   #9
Just finished, though I still need to replace the bumper cover.
Anyway, for anyone doing this, I highly recommend the proper tool. Did not break one plastic rivet when using it!
Also, rather than cutting all those slots, I just hacked out a section and backed with some plastic mesh. Looks racier anyway!
-H. L. Mencken
